can I upgrade to 2x...
[Closed] can I upgrade to 2x10 in stages?
I needed to replace the crankset on my HT so I've moved my triple SLX crankset off my FS. I now need to purchase a replacement for my Cove G-Spot and want to go 2x10 but can't afford to replace everything straight away so could I get a 10 speed double crankset and still use the 9 speed chain and cassette for a while?
Posted : 12/11/2011 10:52 pm
Yes, first go 2 then go 10.
Posted : 12/11/2011 10:53 pm
Yep, no worries.
You presumably know you'll also need a new rear mech when you change to 10 speed?
Posted : 12/11/2011 11:40 pm
I think I read on Sheldon Brown, that there's need to replace a triple with a double anyhow... as the cranksets are identical, just with different chainrings.
Going on that surely it would be more economical to purchase 2 new chainrings 26/38... Saving you about £100 with which you could start to buy the other bits? Or am I missing something?
Posted : 12/11/2011 11:54 pm
njee - yep I know I'll need a new rear mech and shifters, hence the extra expense.
chris - I need a new crankset no matter what so I was looking to get something that will last into upgrading to 2x10
I looked at the new 2 ring XT crankset but it states that it can only be used with a 10 speed chain, and I can't use a 10 speed chain on my existing 9 speed cassette
Posted : 13/11/2011 10:44 am
 mrmo
You know you only need ONE shifter? the front is just set up so you don't use all three positions.
As for the 9spd/10spd thing, i am using a ten speed chainset on the roadbike with a 9spd chain with no issues and see no reason why it should be different on the MTB.
My MTB has XT cranks, and TA 26/40 chainrings, mounted in the bottom and middle positions.
Posted : 13/11/2011 10:48 am
