Can I upgrade the L...
[Closed] Can I upgrade the LED's in my old cateye tripleshot to the next gen LED?
As the heading really
I have [url= http://reviews.mtbr.com/blog/cateye-tripleshot/ ]this model[/url] cateye tripleshot nimh battery pack, Its pretty crap compared to the latest gen, but the head unit seems really well made, can I just simply pop down to maplins buy 3 new LED's and a soldering iron?
Or am i missing something? (probably there is a lot I'm missing)
Ta
Posted : 17/12/2010 2:26 pm
Hi Nasher,
Your best bet would be to email troutie and see if he can convert if for you. It will come back good as new and tonnes brighter 8)
Posted : 17/12/2010 4:41 pm
[i][b]I Think[/b] [/i]that one is luxeon 3 w leds in which case cree xpes are a direct replacement and will increase the light greatly - even using the same optics should be OK.
XPGs are a much better led again - but will require different optics and I am not certain the driver is the same.
Try checking on candlepower forums for info
Posted : 17/12/2010 4:46 pm
TJ, roughly how many lumens would the xpe's give? I think my current light is a 130 lumens if I can get double that with a tesco LED torch on the helmet then I will be happy....
Posted : 17/12/2010 5:38 pm
I upgraded my Doubleshot a few years back using the instructions on [url= http://www.candlepowerforums.com/vb/showthread.php?163278-Cateye-Double-SHot-mod-Lux-3-to-SSC-P4-%28with-Pics ]this Candlepower thread[/url]; unfortunately it's sufficiently old that the pictures no longer work.
The LEDs in the Doubleshot - and presumably then the Tripleshot as well - are a straight swap for Seoul P4s, although they are bare emitters rather than ones mounted on stars so the swap is a bit fiddlier but still fairly doable. The hardest bit is removing the screws that hold a plastic bit over the LEDs which are made of soft cheese and extremely difficult to get out intact; luckily you don't really need all of them for it to still hold together (mine is missing two of six IIRC!).
My upgraded doubleshot isn't a patch on a Magicshine on high or some other recent equivalent but it was a decent upgrade from what it used to be and well worth doing.
Looking on Dealextreme the P7s look very similar to P4s; I wonder whether they would fit? My doubleshot has been retired now, so maybe it's worth an experiment... ๐Ÿ™‚
Edit: The tesco torch I have is brighter but muuuuch narrower; the upgraded doubleshot is far better in terms of spread.
Posted : 17/12/2010 5:44 pm
I don't for sure know rthe current that the cateye uses. Double the light perhaps? 130 lumen sounds very low for a triple.
A cree xpe at 1 amp is 240 lumen ish - theroetical max. maybe 150 at 3/4 amp
Posted : 17/12/2010 5:47 pm
I did this conversion to a dead triple shot a while ago
not really the same as a led swop but the owner was very pleased with the outcome
http://forums.mtbr.com/showthread.php?t=608544
Posted : 17/12/2010 7:12 pm
wow troutie spettacolo!!!
I see that you build lights commercially, do you do conversions like that triple shot for people?
I have 2 thta needs converting, and can I use the same battery..
A
Posted : 17/12/2010 7:23 pm
