As above got the chance off some 15 bolt through that have come off a F120 and wondering if it's a straight swap onto my F100? Or do I have to change some internals?
Tried MOJO but there shut today.
Thanks for any advice
Yes I'd say.
Let the air out of the fork & turn it upside down for an hour to let the oil drain into the uppers. Then take off the foot nuts & swop your lowers.
Re inflate.
Just space them down to 100mm with the fox spacers only cheap a few quid of the fox site
The lowers are the same on the f100 models, its only the stantions and internals that are different to make them as light as possible. It will be a straight swap providing that the years of the lowers and uppers are simlar since they messed about with the rebound cartridge over the years and i believe that the lowers on the later forks have a bigger hole
It's a 100mm fork going into 120 legs, so I'm thinking the lowers are the same length?
So don't think I will need spacers?
Indeed, no spacers required ๐ nice and easy straight swap
cruzer is it as simple as dickie says above
anyone?
dirtyrider
Thank you
