Can I just buy a 20...
[Closed] Can I just buy a 203mm adapter and rotor and fit them to my brakes?
As above, and with this, will I be able to take the 180mm off the front and put it on the back?
Posted : 03/03/2014 8:35 pm
What is on the back now?
A 180 front adapter does not generally do 180 on the back the spacing of the bolt holes is generally compatible with a 20mm smaller disc at the back unless things have changed recently?
Posted : 03/03/2014 8:38 pm
160mm on the back. If I have to buy a new adapter for the back thats no biggie as if the front is changed ill have a spare 180 rotor.
Posted : 03/03/2014 8:41 pm
Depends on your forks, some aren't warranted for 203mm.
Posted : 03/03/2014 9:13 pm
And the frame, some only have clearance for 160 or 180 rotors.
Frame and fork are ?
Posted : 03/03/2014 11:34 pm
 br
What, for riding around Oxford? 😉
Posted : 03/03/2014 11:36 pm
Fork is Rockshox XC32TK 120mm.
Frame is Lapierre X-Control 110.
b r - I think theres a disease called upgraditus, I dont care if I need it, its shiney new so I must have it!
Posted : 04/03/2014 2:46 pm
 core
Some frames won't take a 180mm rear, mine won't.
160 rear = 180 front
180 rear = 200 front
etc
Posted : 04/03/2014 3:04 pm
Maximum rotor size for XC32s is 210mm so you will be fine, no idea what the largest rotor the back will take though.
Posted : 04/03/2014 3:36 pm
Meh My Pikes are listed as 200mm maximum, and Rockshox said that they wouldn't fit.... strange i'm now running 203mm rotors front and rear
Posted : 04/03/2014 11:06 pm
 core
That 3mm is hardly a huge difference is it.
Posted : 05/03/2014 8:05 am
depends if you like warranty on a brand new pair of £600 forks?
Posted : 05/03/2014 5:02 pm
