Can I flip my grann...
[Closed] Can I flip my granny ring??
[#1401736]
I have the above crankset and the granny ring is starting to look a bit worn. I'll eventually replace it with a steel one (prob deore or should I think about something else?), but in the meantime, can I just flip it over as it has no ramps/pins etc?
Posted : 11/03/2010 11:30 am
Yeah, flip it. I've done it.
You can generally pick up Deore steel granny rings for a couple of quid when the fashionistas get rid of them. 🙂
Posted : 11/03/2010 11:34 am
Sorry - meant to say its the XT crankset with the crap aluminium granny ring with no ramps.
Posted : 11/03/2010 11:37 am
Yes, it's fine - if there are no ramps/etc then it'll work just the same.
Posted : 11/03/2010 11:41 am
there are never ramps on granny rings, but yers, replace it with a deore one if you want it to last.
Posted : 11/03/2010 11:49 am
Providing there's no countersink that the bolts fit into, flipping it should be fine.
Posted : 11/03/2010 11:57 am
my alloy XT inner has countersunk holes, not sure what effect they would have if the bolts are long enough
Posted : 11/03/2010 12:00 pm
On an M770 they are countersunk.
Posted : 11/03/2010 12:07 pm
Yup - its the 770 with countersunk - will it be that much of a problem?
Posted : 11/03/2010 12:18 pm
Reversing may make your granny/middle shift a bit less slick. I think the teeth spacing is optimised for it to work best in one direction only. But shouldn't be a major problem - just might be a bit clunky.........might be fine.
Posted : 11/03/2010 2:09 pm
just file the hook's off the teeth and leave it be. If there's no hooks, then it's not worn...
Posted : 11/03/2010 2:35 pm
Even more bodge-tastic - leave it the right way round, but rotate through 90 deg so the teeth that see most loaded most often are now in a 'dead-er' spot in the pedalling cycle.....
Posted : 11/03/2010 2:55 pm
or remove it completely, granny rings are for wimps. In fact remove your middle and fit a 86t big ring and a 11-11t 9spd cassette. Thats for real men.
Posted : 11/03/2010 2:58 pm
surely it would be OK if you reversed the chain too ? Just look for the direction markers...
Posted : 11/03/2010 2:59 pm
this reminds me of the 4 day underpants plan:
day 1: normal
day 2: backwards
day 3: inside out
day 4: inside out & backwards
Posted : 11/03/2010 3:02 pm
If you reverse it the bike will go backwards when you pedal.
Posted : 11/03/2010 3:18 pm
silly, you just have to pedal backwards!
Posted : 11/03/2010 3:21 pm
But then what about the direction arrows on the chain?
Hmmm tricky one.
Posted : 11/03/2010 3:23 pm
unless you buy the cheaper "clockwise only" variety ?
Posted : 11/03/2010 3:26 pm
bristolbiker - Member
as an artist not a engineer ( 😆 ) i'm intrigued to know if this is accurate/would actually work?
Posted : 11/03/2010 3:34 pm
Flip it, she'll thank you for it.......
Posted : 11/03/2010 3:43 pm
As it happens some road Shimano chains are designed to only rotate in one direction.
I doubt rotating the chainring 90 degrees would make any difference.
Posted : 11/03/2010 3:44 pm
photos ? It's not April 1 yet you know...
eeek:
# Inner and outer plates optimise shifting over the chainset and cassette
# Outer plate designed to reduce the chance of chain suck
I'm still not sure it's not a joke...
Posted : 11/03/2010 4:17 pm
I can squeeze another monthor so out of outer road chain ring like this. Yes, it isn't ideal and the shifting pins are in the wrong place..... but I like to change the transmission on the commuter in the spring, so the new-ness of a fresh chain/cassette/rings lasts as long as possible through spring/summer before the kack of autumn/winter gets at it again! 😉
Posted : 11/03/2010 4:24 pm
Errr all chains have inner and outer plates! The inner ones are the narrow bit of the chain and the outer ones are the wide bit of the chain!
Posted : 11/03/2010 4:31 pm
Nope it's fact, sorry FACT.
Profiled to shift better, which kinda makes sense.
Posted : 11/03/2010 4:35 pm
inner and outer [b]outer[/b] plates I assumed...
Posted : 11/03/2010 4:36 pm
Aye, on reading that back it does sound a bit div-tastic! What I was trying to say was that the tooth spacing relative to the bolt pattern is different if you reverse it - hence the recommendation that the chainrings must be fitted with the writing pointing out (or in, or what ever) with the wee tag things lined up.............
Posted : 11/03/2010 5:05 pm
As for going back to the countersinking - if you dont have a good solid surface to torque up against you'll deflect the material when some is supported and other bits are not. If the countersink is smaller than the surface it bolts up against you should have no problems other than greater possibility of slippage. Oh, and look for whether the ring is slightly off-centre from the arms (as in chain line, not as in biopace!)
Posted : 11/03/2010 5:15 pm
Sounds a bit pervy to me...
Is it legal?
Posted : 11/03/2010 5:30 pm
but as 4 doesn't go into 22 the quadrants are already different, and anyway the little ring doesn't have any lifting pins or owt. But my joke revealed the info that there are handed chains only designed to run one way round, which I'd never have believed!
Posted : 11/03/2010 6:11 pm
Most rings are designed to run one way due to ramping and pins that prevent chain fall-off. But the granny has none of these usually, and it's orientation relative to the arm is unimportant.
Posted : 11/03/2010 6:16 pm
The BlackSpire Chuck ring is a brilliant steel replacement granny. If your not anal about weight they take a good pounding too. You can get them for under a tenner usually.
Posted : 11/03/2010 9:34 pm
