to fit scrader valves or will it compromise them? it'd be done by my lbs mainly for the reason that i don't want to have to buy new inner tubes and i use a car foot pump as i don't have a track pump. they're brand new. anyone else done it?
Yes done it on mine
Tracey
if you do it neatly and carefully and file it round afterwards, i would have thought you'd be fine.
cue a stream of horror stories!
should be fine. I've done it to Mavics before without issue.
You may as well add a small hole between each spoke - don't really need all that material and would save some weight.
Warning: might not be safe.
Just a thought, but how about using the money you'd be paying to your LBS to buy a track pump! 😀
Done it on Mavic rims, lasted for years, didn't even cross my mind at the time it might be dodgy 😳
Won't make any difference to the rim at all. Crack on
obviously you can't add up
Whilst combining power tools and bike maintenance ticks quite a few boxes of manly things to do, rarely I have found the drill to be the answer! 🙂
I see this as the perfect opportunity to buy the DT RimStrip and go tubeless.
You can also get a brass doofer to screw onto the Presta valves that then allows footpump / car tyre inflater use; http://www.justridingalong.com/?product=805 (Chainreaction do them for £1.99) but are out of stock).
lol at nickc 😉
I've been drilling out valve holes for years, it's a tiny amount of metal to remove. Just make sure you file it smooth afterwards. No problmeo!
... or you could scoop your eyes out with spoons
Get the drill out!
Wasn't being entirely serious there (hence the :D), but really, you can get a track pump for £20. Seems a bit daft to go taking a drill to an expensive piece of kit.
i don't think my lbs are gonna charge me 20 quid to drill a couple of rims when i'm paying them 60 quid to build the wheels up anyway. besides, i'll need to replace the inner tubes i'm using which will cost me 4 quid each and i'll want a spare for on the trails.
so a pump = 20 quid
tubes = 12 quid
TOTAL 32 pounds!
that's 32 pounds i could have spent on beer.
