Can i convert my Fi...
[Closed] Can i convert my Fireball (lumicycle style) lights to LED's?
I have a barely used set of Fireball lights (think Lumi Halogen)
They are well made and use a 12v Nimh (heavy) battery that drives the lights at 13.2v according to the bumf.
Question, do i sell them as they are and if so how much?
or will they easily convert (cheaply)
any help much appreciated from you techy gods.
Posted : 22/10/2009 11:12 am
You can convert them using the cutter kit. Triple led with a buck driver would be best. Get you about the equivalent of 20W halogen ( or a bit more) with the current drain of 10W
http://www.cutter.com.au/proddetail.php?prod=cut757
Posted : 22/10/2009 11:21 am
Now that looks confusing..
Which bits would i need? All of them?
Do i need to have some experience of soldering, etc?
Posted : 22/10/2009 11:30 am
You need the triple led pcb, optic and a driver for each light unit. You already have the housings do you not. Yes you need to be able to solder - a few small conections to make - 8 IIRC You probably need a new switch as well. You also need to make sur tht you have a good thermal pathway to remove excess heat. Have a look on candlepower forums for more advice.
Posted : 22/10/2009 12:37 pm
A few of us off here are looking to put an order into cutter, I can give you a list of what you need if you like.
You will need a heat transfer method ie heatsink IMHO.
Posted : 22/10/2009 1:08 pm
Cutter do a heat sink almost the right size, Lumi's have a flat at the bottom which you'll need to file off, but it ensures a nice tight fit one you have.
Posted : 22/10/2009 1:32 pm
Thanks for all the advice guys, any idea how much Chucky?
Posted : 23/10/2009 6:39 am
mail me (in profile) and i'll get the prices off the cutter site and let you know.
Posted : 23/10/2009 8:25 am
