Singlespeed Chainse...
[Closed] Singlespeed Chainset
 jlc
[#974638]
Looking at building up my Genesis IO frame and deciding on a Chainset. All my other bikes have hollowtech BBs so to make things easier it seem logical to go with a chainset that uses that so I don't need extra tools and can swap etc. This probably means getting an lx or xt chainset and taking off the rings etc. This will work ok but I do like the look a singlespeed specific chainset. Are there any wich run on hollowtech BBs? Or is it best to go for a Middleburn square taper? Any other singlespeed chainset recommended? Any thoughts would be much appreciated.
Posted : 22/10/2009 10:45 am
I ran a compact campag centaur, came with a 34t unramped ring and a nother huge one, it is a 10 min job to strip and lube the external BB bearings so will last indefinately if you look after it, and Middleburn do a selection of ring sizes if you dont want or wear out the 34t..
Posted : 22/10/2009 10:59 am
i'm going to go for middleburn squaretaper with SKF bottom bracket, will let you know how it goes.
Posted : 22/10/2009 11:51 am
