Can i convert a Hop...
[Closed] Can i convert a Hope 135mm to 148mm ?
Ive a 135mm pro 4, had next to no use, only fitted to a 26" rim. Thinking of dismantling it and building it to 148mm(prob 27.5 to give me a mullet set up should I ever wish to go that way.
I know you used to be able to use one of Hope's kits for 135-142, or 142 to 148, but im not sure if you can go 135 to 148.
Posted : 09/05/2022 7:46 pm
If you go to 142 you can get universal spacers to take it to 148. You need to space the disk as well and the kits come with this spacer too. Not sure if Hope do a dedicated kit. Worth asking them, they are ok at responding to tech questions.
Posted : 09/05/2022 7:59 pm
For the Pro4 you're good, yes.
says you need HUB493.
Posted : 09/05/2022 8:03 pm
