Can brake master cy...
[Closed] Can brake master cylinders suck air through the lever actuator?
 FOG
My SLX rear brake has been spongy of late so set off to bleed it. everything seemed OK but air still seemed to appear in the master cylinder reservoir as if it was coming in through the lever plunger. Is this possible? If so can you rebuild it or is it another brake buy?
Posted : 18/12/2012 5:30 pm
Yes it's possible, and no, you can't rebuild it as Shimano don't do spares.
Posted : 18/12/2012 5:33 pm
 FOG
Oh boy more money to spend! Still the other current disc thread has some cheap suggestions.
Posted : 18/12/2012 5:39 pm
Smug mode on. Had this with my Avid elixer cr, got lever rebuild kit £25 , job done.
Posted : 18/12/2012 5:45 pm
[url= http://www.parker-international.co.uk/18984/Shimano-SLX-M666-Brake-Lever.html ]New lever £25[/url]
Posted : 18/12/2012 5:48 pm
 FOG
It's from the earlier 9spd series any reason why the 666 won't work?
Posted : 18/12/2012 5:51 pm
Hoses might be slightly different I guess, but with an appropriate fitting kit (olives/banjo etc), I reckon it'll work just fine
EDIT - see [url= http://forums.mtbr.com/brake-time/mixing-old-caliper-new-lever-743961.html ]here[/url]
Posted : 18/12/2012 5:55 pm
