as title
Posted : 22/09/2013 5:28 pm
Remove u-turn adjuster with Allen key, 24mm socket on top of left stanchion. Undo, change spring, do up.
[url= http://pondering-panda.blogspot.co.uk/2008/09/tutorial-fork-service-rockshox-pike-426.html ]Service article[/url]
Posted : 22/09/2013 6:06 pm
spring seems stuck? cant pull it out - is this normal? Pike 409`s
Posted : 22/09/2013 6:16 pm
http://www.tftunedshox.com/info/rockshox_spring_fitting.aspx
Use this guide from TF Tuned instead.
Much clearer and explains why you think the spring is stuck.
Posted : 22/09/2013 6:24 pm
peferct answer, one more thing - does anyone know where i can get the bearings from :)??
Posted : 22/09/2013 6:48 pm
