Campy 10 ergos with...
[Closed] Campy 10 ergos with Shimano 10 mech/cassette
Hi guys, anyone used this set-up, or know if it works?
Posted : 13/03/2010 8:48 am
No, it won't. 10spd Ergos will work perfectly with a Shimano 8sp cassette or you slightly bodge to 9spd
Posted : 13/03/2010 9:20 am
The rear mech won't work as the pull is different, however the cassette will work to a fashion. But it'll be better to stick to either all Campag or all shimano (or Sram)
Posted : 13/03/2010 9:57 am
There is some info on http://www.highpath.net/
about indexing and compatibility
the distance that the rear mech has to move sideways to be directly under the next sprocket is
10 sp (Campag) 4.15 mm
10 sp (Shimano) 3.95 mm
so this will mean a difference of 9 x 4.15mm=37.35mm and 9 x 3.95mm =35.55mm over the 10 sprockets.
Posted : 13/03/2010 10:10 am
 flip
It'll be poo ๐Ÿ™„
Next....
Posted : 13/03/2010 10:16 am
http://www.ctc.org.uk/desktopdefault.aspx?tabid=3946
Posted : 13/03/2010 10:46 am
[url= http://www.jtekengineering.com/shiftmate.htm ]These get good reviews[/url],though not tried one myself. I had another link to another solution but can't find it unfortunately.
Posted : 14/03/2010 10:24 am
campy ๐Ÿ™„
Posted : 14/03/2010 10:42 am
