Calling diabetics F...
Calling diabetics Freestyle libre 2 Garmin head unit
Has anyone been able to connect their head unit, mine is a Garmin 1000, connect to their freeStyle libre 2 sensor?
with the new no touching to scan reading since the update I was hoping this may be possible?
I don’t fancy wearing a watch, I have not done so for 15 years, so don’t fancy going down that route just for riding. But would if my head unit won’t work.
thanks in advance for any knowledge. I know there might not be much info as the update has only just happened.
Posted : 20/07/2023 8:48 pm
Whats the new no touch scan, my son hasn't mentioned it to us ? He's 22, why would he ?
Posted : 20/07/2023 8:53 pm
You may need to install xdrip and then something else...I was using Libre 2 and never found a way to display the result - notifications about high or low blood levels would appear but not the actual result.
I'm using CamAPS and a Dexcom g6 - Garmin have a Dexcom widget but it needs the Dexcom app installed on the phone - which can't be used with CamAPS. I've not found a way to get the CamAPS data on my Garmin and I suspect I may have to try and install something else to try and show the readings.
Posted : 20/07/2023 8:54 pm
@fossy There is an update to Libre app that now means the libre 2 doesn't need a scan to get a reading (sounds like it does what the libre 3 does). However, the app is jumped on iOS and has been removed from Apple app store until it is fixed. I think android it works though.
Basically the libre 2 will now send result to phone so doesn't need to be scanned to get a result (I think - I moved to Dexcom g6 about 35 days ago so haven't paid it much attention).
Posted : 20/07/2023 8:57 pm
kelvin reacted
@fossy
Dick Barton is correct.
iv had several emails the latest one today saying the IOS is now up and running again. Once I start my next sensor it will send reading straight to my app.
Posted : 20/07/2023 9:08 pm
Software is all available, it’s just legislation holding it back. Nothing that the Supersapien sensors don’t do, but they’re not a medical device. Hoping it comes in time, would be great to have it on Apple Watch.
Posted : 20/07/2023 9:57 pm
kelvin reacted
Apparently apple version is fixed now so should be available soon. Suspect a new sensor will get it working without scanning.
Posted : 20/07/2023 10:41 pm
 BigR
I have used a libre with a ‘bubble’ Bluetooth transmitter. This sends my results to my phone and garmin every 5 mins using xdrip. I am really hoping the libre upgrade will do away with the bubble device and do likewise but I am not optimistic.
Posted : 20/07/2023 11:57 pm
I just started a new sensor a couple of days ago and the Android Libre 2 app is working flawlessly. To check my levels all I have to do is pull up the Libre app on screen or from the background. I don't have to scan, which will be a godsend when out in the winter. No more trying to get sensor contact with my phone through umpteen layers of kit!
I believe what it's doing now, is roughly the same as the Dexcom kit. I'm no techy expert, but I think that all the extra apps like Xdrip/ Nigh****ch? etc. were developed by users to access the Libre 2's already available, but disabled, continuous broadcast capability.
So, for us to get readings on our Garmin devices (I would dearly love to see my sugar levels on my Edge 530), we'll need a developer to have access to the Libre's code and produce a compatible app as is the case with Dexcom. If I understand things correctly from what I've gleaned on t'internet though, Abbott aren't as forthcoming with propriety information as Dexcom have been.
All of the above should be taken with a healthy pinch of scepticism as I really don't know what I'm talking about.
Posted : 21/07/2023 9:28 am
Just heard about this at our quarterly review this week.
My daughter is worried that it will mean that she has to use her phone in school (strictly verboten). So it doesn't do anything until you open the App, then it pulls all of the data over?
Next sensor change is 8 days away, so she has time to think about it.
Posted : 21/07/2023 9:39 am
My gf was using Libre 1 and then Libre 2 connected to XDrip+ (on android) and then the garmin xdrip widget/datafield to display numbers on both her garmin watch and 530. She's on Dexcom now (as it connects with her pump) but I'm pretty sure it was working fine when she switched.
So I think the trick is you need to use Xdrip instead of the Libre app. Guide here: https://www.minimallooper.com/post/how-to-setup-freestyle-libre-2-and-oop2-to-use-a-native-bluetooth-connection-in-xdrip
And then use the Xdrip datafield on your garmin here: https://apps.garmin.com/en-US/apps/5a3e2cda-12f0-4afd-88ed-000e67a68d84
Tbh, Xdrip seems to be a better app than both the libre and dexcom android apps.
Posted : 21/07/2023 9:42 am
The sensor's just the same as before. If you start it with your phone, you'll get continuous readings, you can actually see your readings change every minute on screen without scanning while the phone is in range of the sensor. I believe though, if you start it with your reader, you'll still only get scanned readings, like you got previously with the phone and won't get the benefit of the continuous reading. I assume your daughter uses a scanner rather than her phone during her school day, so it'll just be business as usual for her.
Posted : 21/07/2023 9:51 am
Thanks.
Will look into it.
Posted : 21/07/2023 9:54 am
Garmin has a Dexcom datafield and widget, but it seems to need Dexcom app running on your phone - which is fine, but I'm not using that as I'm running CamAPS and that isn't available.
I'm going to have a nosey at the xDrip thing as I really would like to see this on my phone or head unit. I haven't looked at xDrip, so no idea how it will work with the apps I've already got (CamAPS, MyLife (Ypsomed) and Glooko) - I'm hoping it will just sit alongside and gather the data without impacting what is already there.
Posted : 21/07/2023 10:14 am
As a few have said - new update means constant glucose reading when sensor started with librelink AP. Son (13) had a new one on last night, scanned it with his iphone, running the app, rather than the reader. Works really well which surprised me having seen the issues over the last week.
Challenge we face is we now can't use the reader which is an issue at school as he has to get his phone out - but last day today so they'll have to deal with it. Previously, if you starter sensor with reader, you could still use the phone app to scan.
The biggest issue though now is we can't get the LibreLinkUp app to work. If you've not used this, it used to send an reading to my phone when he scanned himself with his phone. Was ok for sleep overs or if up playing football etc. Would be even better now it will 'constantly' have a feed, but i can't seem to get it to work.
Anyone else experienced that yet?
I wonder if integration to 3P apps/systems is yet to be rolled out, hence the OP's issue??
Posted : 21/07/2023 10:49 am
New IOS app is still very glitchy after about 5-6 days. Hoping that it will gradually start to improve over time. Im not even sure if mine is alarming properly even with the settings restored. The constant feed without scanning on the phone doesn't seem to be very consistent.....and hence im not very confident it is actually doing it, or rather just displaying my last reading. i am therefore still scanning with the phone quite often. Sure over time it will improve....I hope!!
Posted : 21/07/2023 11:12 am
TedC reacted
The fixed Apple app only went live yesterday or the evening of the day before...are you sure you are using the latest Apple version @robw1?
@latham2104 - rather than taking the phone out constantly to check readings, does he have a smar****ch that could display the reading? Or if he handed the phone to the teacher and it was on the teacher's desk so if there is a significant change in levels then it can be spotted and acted upon? Saying that, I'm not sure the school can do anything to prevent a medical requirement needing the phone to be used - as long as your son doesn't abuse the use.
Posted : 21/07/2023 12:02 pm
I'm a Libre 2 user and this is an advancement I'd been hoping for for some time. I had been recommended miaomiao (not meowmeow, that'd be highly unethical)  by my consultant to achieve this but didn't fancy an additional sensor on my arm given how often I catch it anyway - I decided against it in the end.
Although I can get low sugar alerts via bluetooth connection between phone and my Garmin Forerunner, so I assume I may be able to stream blood sugar  levels through the same route? I'll be installing a new sensor in a couple of days so I will investigate.
You hear all the diabetic news first on the STW forum!?
Posted : 21/07/2023 12:28 pm
There isn't a native Garmin link for Libre (yet), so I suspect you'll need to install a 3rd party app (xDrip seems to be the one) and then install the widget and data field (there might even be a watch face as well) and then you will get the results.
The high/low alerts are 'alerts' so get shown as notifications on your devices, they aren't the same as the continual blood levels...
However, it should hopefully be straightforward enough to do and won't require anything additional on your body, maybe just an additional app on your phone.
Posted : 21/07/2023 1:28 pm
@DisckBarton - thanks for the comment. Yep - we're looking into the Smart Watch - we have an old Apple Watch 3 knocking around but i can't see that working. Do you have expereince in setting it up to receive the reading? Any tips?
Chances are he'll have one before back to school in September which will elevate the phone in school issue. Handing to teacher is a no go for various reasons and you're right, no medical responsibility.
@Dr_Brakes - miaomiao was useless in our experience. Wouldn't recommend wasting your time or money on it.
Personally, i think the advancement is great. Seems a good stop gap until Libre3 is available on NHS and means I dont need to self fund a Dexcom.
Posted : 21/07/2023 2:00 pm
@latham2104 - afraid I've zero experience of setting this up. I've moved on to Dexcom G6 with my Ypsomed pump which has allowed hybrid CGM (which is awesome!), but only been on it for last 37 days. BEfore that, I was on Libre for about 4 years, but I was happy with the alert notifications.
I'm now needing to take a look at xDrip, reading things it seems I'm going to have to reinstall the Dexcom app and set up a ghost follower for xDrip to pick up the detail (but it that is all it is, then I may see if the native Dexcom widget and datafield will work on the Garmin devices and then I don't need to worry about additional apps).
This part of it - getting the result on a Garmin device is all very new to me, plenty of others have done this already, but I'm still trying to work things out...so not the best person to ask. I'm still on a few libre forums so have been reading up on the new thing - which is a bit of a nuisance as had this new functionality been known 7 weeks ago, I wouldn't have been moved onto the Dexcom as I had everything else in place. Dexcom, however, seems to be more accurate and is much less vulernable to being knocked off my arm, so I'm quite happy to be using that.
Posted : 21/07/2023 2:43 pm
 scud
My daughter is Libre 2 user, app stopped working last week, then we went to download new version and missing from Apple app store, finally managed to download new app yesterday, but it is still requiring that she swipe, not working as CGM as mentioned above?
Will it only start working when she fits new sensor in a weeks time?
Posted : 21/07/2023 2:59 pm
It only works when a new sensor is started. The Apple version of the app had a major issue and it was removed from the store, but that got fixed and was made available again the day before yesterday (I think).
Posted : 21/07/2023 3:52 pm
So just started the new sensor, and no scan needed for live updates.
I have a new question. Can I get readings on my Lock Screen? So just glancing at my phone
iPhone XR latest update installed.
been googling for the last hour, but can’t find anything
Posted : 22/07/2023 7:25 pm
For iPhone, does anyone know what software version is required. Checking my mums and she’s on v 2.10.1.7653. I can’t check as she’s just  knocked the sensor out and hasn’t got a spare so hoping when she puts a new one in it works for her.
Posted : 22/07/2023 7:54 pm
Not sure if this helps
Posted : 22/07/2023 8:25 pm
How does Apple deal with notifications on lock screen? I'm not on libre but I had to set my lock screen notifications to all (on android) rather than secret. I now see all my notifications but it also shows my CamAPS result as well.
Might need to set your notification level to ALL to see if they show.
Posted : 22/07/2023 8:38 pm
Thanks @DickBarton
tried all sorts but won’t show up.
Posted : 23/07/2023 7:12 am
You need juggluco on your phone and xdrip on your garmin... miou miou/ bubbles no longer required, I've got this on my fenix and at a glance bg readings are amazing 😀 best advice is to join freestyle libre geeks group on Facebook... super helpful bunch .... I was struggling to get results ended up with a guy offering to give me a call to talk me through set up. ... ive not updated my phone as don't want to risk having to faff about!
Posted : 26/07/2023 2:02 pm
 scud
Thought it probably a question to ask on here, since the Libre 2 update, if my daughter has high glucose, when you had to scan the sensor, if she was high, but had insulin on board working, once you scanned the sensor it acknowledged this and stopped alarming all the time.
Now if she is high, she checks her blood glucose and it does not want to give her any more insulin, but the alarm keeps going off every five minutes until she goes back under pre-set upper limit on Libre Link app?
We try to give her a sensible diet, but as a 13 year old girl going through puberty, her BG is up and down constantly, and ratios that worked yesterday, can be way out tomorrow!
Signed
A very sleepy dad....
Posted : 01/08/2023 3:02 pm
@scud Now if she is high, she checks her blood glucose and it does not want to give her any more insulin, but the alarm keeps going off every five minutes until she goes back under pre-set upper limit on Libre Link app?
i hear you on this. We have the same. Dont think you can fix that.
Are you using the LibreLinkUp app as well? This will send the alert, and 'constant feed' to your phone as well. Very handy. This seems to be owrking really well for us. It does however alarm on my phone, as well as juniors phone when high/low. But i'll take that for the peace of mind it offers when he's out and about.
@stoddys  I have a new question. Can I get readings on my Lock Screen? So just glancing at my phone
we have that on juniors phone on his lock screen (iphone). Settings>notifications>librelink> scroll down to the bottom and you should see 'Lock Screen Appearence' and then turn Show Priviews to Always.
Regarding my previous posts above. Managed to get everything talking together. Just uninstalled Libreview on juniors phone, and librelinkUp on my phone. Reinstalled LibreLink on Junior, deleted the existing connection. Then asked again for it. Reinstalled LibreLinkUp on my phone, accepted the invite, and boom - constant reading on my phone streaming from his.
Posted : 01/08/2023 3:27 pm
 scud
Are you using the LibreLinkUp app as well? This will send the alert, and ‘constant feed’ to your phone as well. Very handy. This seems to be owrking really well for us. It does however alarm on my phone, as well as juniors phone when high/low. But i’ll take that for the peace of mind it offers when he’s out and about
I think it is a great system, but with a teenage daughter going through puberty, we have had highs / lows all over the place, and if she is high, we are getting alarms every 5 minutes for hours until her bloods come back in range, even though she has the insulin on board to bring it down, averaged about 3 hours sleep for the last week now! But as you say, i'm glad it works well and it is piece of mind, even if i do go slowly mad...
Posted : 01/08/2023 4:05 pm
I'm surprised more people aren't using xdrip+.
With the Freestyle libre 2 it's pretty great - the sensor talks to the phone, phone feeds datafields on my Garmin Fenix watch and Edge headunit when I'm road riding. Can snooze low and high alarms for a preset period (I use 30 mins for lows, 1 hour for highs) (useful when out riding, or in meetings) including from the watch, which is _amazing_ if you are in the middle of something, and have them set them not to re-raise if the blood sugar is trending the right way.
Big plus for me is being able to calibrate the sensor readings with blood tests too, can find that the Libre numbers are comically out. Doing a few blood tests keeps it within 0.2 mmol/l ish for me.
Posted : 01/08/2023 4:45 pm
@superdan Sounds brilliant, only it doesn't seem to be available for iphone?
Anyone know of an equivalent conduit for apple devices?
Posted : 01/08/2023 5:12 pm
 scud
It does sound really good, but again daughter and i are both Apple users?
Posted : 01/08/2023 5:20 pm
@latham2104
can you see live numbers for the readings or just alarms for high and low?
Posted : 01/08/2023 9:49 pm
Not an iPhone user, but a quick Google suggests Shuggah https://apps.apple.com/sa/app/shuggah/id1586789452 should do something similar?
Posted : 02/08/2023 6:52 pm
Hi there,
Apologies for resurrecting this thread, especially if this is old news, but I was out on my bike tonight with my Garmin 530 displaying blood glucose levels from my Libre 2 sensor!
First I downloaded the LibreLink app from Google Play onto my Pixel 7. That's the app that lets your partner/parents/friends monitor your glucose levels remotely....never gonna happen. I then invited myself, and accepted the kind invite to follow myself with this app. Next I went to Garmin Connect IQ and downloaded the CGM Connect widget by bruder_jakob. I then plugged my Edge 530 into my laptop and synced it with Garmin Express. The CGM widget was displayed in the list and if you click on the three wee dots beside the name of the widget, a bunch of options appear. At the top is the bit where you put in your LibreLink login details. Once that's done I believe what happens is that my phone reads my Libre 2 and transmits the data to the LibreLink app, then the CGM widget on my Edge 530 gets the data from LibreLink and displays it on the screen. It works!
Only caveat is that it's a widget designed for Garmin watches. Pretty much all the Garmin watches except my Instinct Solar. It works great on my Edge 530 head unit though, but I had hoped I would be able to display my glucose levels as a data field alongside others. As far as I can see, it doesn't work that way. You have to navigate to the Widget menu on the head unit to view your sugars, or just leave it on screen while you ride. That's what I did tonight. I'm quite pleased with it though as I generally ride with my phone tucked away in my Camelbak, so a couple of button presses are still quicker than all the faff of digging around in my bag!
C.
Posted : 07/11/2023 10:24 pm
DickBarton, kelvin, kelvin and 1 people reacted
That is what I'm wanting to do with my Dexcom G6, but I use CampAPS FX and it isn't able to share the data. I did contact the CampAPS FX team to ask if it was possible and it is on the backlog of things - which likely means it might get looked at in a couple of years time.
Like @Beagleboy, my phone is well packed away whilst riding so having it on my Garmin would make things a bit easier, not a show stopper for me and I'm really not keen on installing a 3rd party app to try and work around it, but it is more than just a nice-to-have for me, but not enough for me to try and work around it.
A shame really as the Dexcom has a widget and data field native to Garmin that would work brilliantly, but you need to uninstall the Dexcom app to run CamAPS FX.
Posted : 08/11/2023 8:43 am
Libre 2 user here, been using xdrip by Andreas-May from Connect IQ for a while now and it works pretty well, using data field, watch face and widget on my F6Pro and data field on my Edge 1030+.
Posted : 08/11/2023 3:17 pm
@Beagleboy - Thanks for that info, I may well be giving that a go with my Fenix when I get home It will certainly be very useful being able to monitor from my watch.
Posted : 08/11/2023 4:54 pm
Apps installed and it works brilliantly - I've wanted to be able to view my readings on my watch for ages and now I can!
Thanks for the instructions, much appreciated 🙂
Posted : 08/11/2023 9:13 pm
Anyone have an easy way to do similar on an Apple Watch?
Posted : 08/11/2023 9:25 pm
Thanks for resurrecting my post, I was so close but gave up. <br />I managed to get night scout on my Garmin 1000 even got it on the screen with speed etc but it won’t show any readings.
if anyone could send me a dummies way of getting it right. I have an apple phone and Garmin 1000. I do get readings on my iwatch, with either gluroo or nightscout not sure how but fumbled my way through.
id appreciate someone sending me some help to get me over the line.
Posted : 09/11/2023 7:18 am
Hi Stoddy,
With the LibreLink + LibreLinkup apps on your iPhone, and the CGM widget from Connect QI on your Garmin. Will this give you live glucose updates on your Garmin as it does on my Android? It was really simple to setup, because I managed it.
C.
Posted : 09/11/2023 11:32 am
Hi beagleboy
thanks still trying, you’ve given me a new lease of life.
on the fill your details bit. GCM Connect, did you put anything in the libralink token box. And the libralink patient ID box?
thanks Stoddy
Posted : 09/11/2023 1:48 pm
@Stoddys
No, I just put in the email address and password I used to activate my LibreLinkup account.
Posted : 09/11/2023 2:07 pm
Ok thanks. Time to get back to work will try again later
Posted : 09/11/2023 2:15 pm
@beaglboy
embarrassing moment. I was expecting to see a data field on the screen.
after a lot of googling you can get to widgets by swiping down then across, who knew! Also found out that’s where the weather forecast is. Every day is a school day
now have the widget showing my readings.
thanks.
Posted : 09/11/2023 4:46 pm
had to write!
just got in from a cold Friday afternoon ride and whilst I was putting on the widget on my farming I also down loaded the data version of same app. When you choose what you want to see on the screen choose connect IQ then douse the data app for your GCM. 5 minutes into the ride it came up with my level. Refresh is a bit slow between 2&6 mins but I’m not concerned with that, also has a direction arrow.
thanks all for your help, I’m finally there.
Posted : 10/11/2023 5:03 pm
Need to proof read. ! I was excited
you get the idea. Insert garmin and choose in the appropriate place
Posted : 10/11/2023 5:50 pm
Sorry to drag this up from the past, but has anyone been experiencing problems with getting readings on their Garmin watch recently?
It's been working perfectly for me for the last 10 months, up until yesterday afternoon. Now all I have displayed in my watch is
no LLU credentials removing PW!
I've checked all the settings, password are matching up and Linkup is providing the correct readings but for some reason the CGM Garmin app doesn't appear to be connecting. I'd not touched anything prior to this error appearing and it was working fine before about 5pm yesterday.
Very weird.
Posted : 21/09/2024 1:25 pm
All working on my Garmin head unit, but since installing it, the Garmin goes to sleep after about 10 seconds and turns the screen off. It is still running and recording but screen is turned off - to save battery power according the the message. Press a button and the screen turns on and I see everything, but a pain to have to hit a button to see it...need to find the option to turn screen off to on!
Posted : 21/09/2024 4:56 pm
What are you using? I'm on libre 3, an ypsomed pump running CamAPS FX...I've got xdrip installed on my phone and I think there were 3 settings I needed to set - none needed a username or password...
Posted : 21/09/2024 5:04 pm
I'm using Libre 2, no pump. I'm using  Libre Linkup in my android phone, connecting the CGM Connect widget. Linkup needs a password setting in it, as does the widget.
This seems to be the problem as somehow the passwords on Libre Link, Linkup and the widget had got out of sync yesterday while I was in the gym. After resetting the password for all 3 apps 11 times I've finally got them all talking to eachother at last and it's all now working again.
I hadn't realised just how much I relied on it being so easily available on my watch these days until it wasn't.
Thanks @DickBarton for coming back, though.
Posted : 21/09/2024 6:20 pm
Just moved to the Tandem T-slim and back to Dexcom (g6). The pump connects to sensor, but sensor can connect to phone, so I've got the Dexcom app running on my phone.
I'm running the Garmin Dexcom Data field on my Garmin. When adding it to my data screen, it prompted me to login to Dexcom (via my Connect app on my phone). Enter details and 2 mins later, I'm seeing my blood levels on my Garmin. Not needing to use the Follow option.
I think Beagleboy may have posted similar up the thread, but the T-slim seems to work easily with Dexcom and as the Dexcom sensor is connected to the pump and it seems to just be the Bluetooth connection of the transmitter for the phone app, it all works easily with the Garmin head unit as well.
Posted : 23/10/2024 11:12 am
