Calling Boardman Te...
[Closed] Calling Boardman Team FS owners...
I'm trying to rescue a Boardman Team FS 2012. Could anyone tell me whether all the mounting bits for the shock/linkage are present and correct in the picture below? (aside from the two bearings in the linkage...)
Posted : 09/08/2014 11:28 am
Look about right.
There should be a bolt / support for the top of the shock through the frame and then again for the connection to the link plate. Then the same again for the rear stays to the linkage plate and the the linkage to the frame.
Does that make sense???
Posted : 09/08/2014 2:45 pm
I've got a frame here if you want some photos, email me
Posted : 09/08/2014 5:13 pm
 iany
Would someone be able to assist me too?
I bought a boardman team fs frame, built the rest from bits I had and don't know what the shock mount should look like (the end nearest the seat post), I've got a fox float R installed but there's some slack in it (knock if you pick up the bike)and the bushes don't "fill the gap on the bolt" could someone point me the right way for a pic of where the end of the shock sits on the mount so I can see what sort of bushes I should have?
thanks!!
Posted : 14/01/2015 1:17 pm
