Cages for tool stor...
[Closed] Cages for tool storage bottles
15 Users
I'm thinking these tool-storage bottle thingies are a good idea, especially as my bike has mounts for a third bottle cage under the downtube
This thing is what I'm talking about: http://www.zefal.com/en/front-bags/311-z-box-l.html
The obvious question is what bottle cage to use. There is no need to use a normal bottle cage which allows the bottle to be removed at will. I'd like one that is much more secure and ideally straps the tool-storage thing to the bike. Kind of like a mini Gorrilla Cage I guess.
Any suggestions?
Posted : 18/07/2018 9:35 am
I've been thinking of getting something like this and a side access cage so it'll fit below my current bottle and cage.
Posted : 18/07/2018 9:44 am
This has a thumb screw to retain the contents.
https://www.arundelbike.com/product/looney-bin/
Cheaper options would be a strip of velcro, or a bungee cord
Posted : 18/07/2018 9:46 am
like a mini gorilla cage, from the people that make gorilla cage
http://freeparable.com/monkiicage
Posted : 18/07/2018 9:52 am
I have the tool bottle linked above - really good and managed to squeeze loads in.
I've got the [url= http://www.chainreactioncycles.com/sks-slidecage-bottle-cage/rp-prod54323 ]SKS Slidecage[/url] on my Mega - really secure.
Specialized zee cage.
Although I find it scratches the he'll out of the bottle if that bothers you.
Posted : 18/07/2018 9:53 am
Elite Ciussi, squeezed a little, with added grip-tape. Does the job more than adequately.
Posted : 18/07/2018 10:19 am
I just use a normal bottle cage but if you think it's not enough get some sticky backed velcro and attach small tabs of that to cage and bottle.
Another option is to get a BeerBabe downtube bag. I've the smallest of these (300mm) and can fit a Topeak Mini Mountain Morph pump plus a whole host of tools and spares and still have room.
Posted : 18/07/2018 10:32 am
Just use a normal one as it's the same shape.
Posted : 18/07/2018 10:34 am
I've got one of those Zefal tool bottles linked above and it works fine with a bog standard bottle cage. Although I put mine in the cage mounted to the seat tube rather than under the down tube as per the OP. Would think a velcro strap would give enough security though.
Or if you have the space these frame bags from Decathlon are great. I use one on my Solaris and get a pump and tool roll in there and even a small pocket jacket.
[url= https://s33.postimg.cc/n7p9ixadr/20180608_130439_2.jp g" target="_blank">https://s33.postimg.cc/n7p9ixadr/20180608_130439_2.jp g"/> [/img][/url][url= https://postimages.org/app ]screen capture open source[/url]
Posted : 18/07/2018 11:16 am
I have a couple of those ones that are like plastic bottles with a screw lid that just fit into a standard bottle cage. Work fine but find they can rattle a bit unless you can pack them pretty tightly - can also be a bit of a pain to fish out the stuff at the bottom of the bottle (usually the inner tubes) requiring you to empty the contents out onto the road side. A made of mine has one that is like a stiff sort of neoprene construction with a zip running down the side so you can get access to anything...a bit like a cylindrical pencil case. Seems like a good functional design. No idea what make or brand it is.
Posted : 18/07/2018 11:45 am
Forgot to put the link for the Beerbabe bag - https://www.beerbabe.co.uk/ourshop/prod_6230779-Downtube-Pack-various-sizes.html .
This is it on my Solaris
Posted : 18/07/2018 11:58 am
The bike radar review of the monkii cage concludes keep to smooth surfaces, so I don't fancy that thing
The Looney Bin could work, but I imagine $15 of the $25 is going to go to the advertising team...
Perhaps the simple answer is a normal sturdy bottle cage like with a big elastic band or strap, but under the downtube is a precarious spot
To potentially answer my own question, this thing looks sturdy...
http://www.blackburndesign.com/en_eu/cages/outpost-cargo-cage.html
Posted : 18/07/2018 4:42 pm
I use a Blackburn mtn cage on the underside of my downtube for a tool bottle (the zefal modular one). My advice if you ride technical terrain, fit the cage with nylon screws rather than metal. I'd rather lose a cage and bottle than rip the rivnuts out of a carbon frame
Posted : 18/07/2018 4:55 pm
There are zipped bottle cage tool cases on P-X for a quid at the mo. If you're buying something else...
Posted : 18/07/2018 5:55 pm
I use a Topeak adjustable cage with a Zefel tool container.
See  http://www.chainreactioncycles.com/topeak-modula-adjustable-bottle-cage-2/rp-prod68036
It has a button adjust for quick change to bottle and fine adjust screw to clamp an item in.
Posted : 18/07/2018 10:22 pm
Do you think you could remove the adjustable cage from the fixed section on that? Might be just the thing I need if it does.
Posted : 18/07/2018 10:31 pm
Nearly bought  https://www.halfords.com/cycling/bike-accessories/bike-bags-baskets/topeak-mondopack-hydro-saddle-bag in their flash sale the other day, but it's quite tall, you need ~32cm clearance from saddle top to tyre/guard.
Posted : 19/07/2018 9:06 am
