Cable Brakes on a ...
[Closed] Cable Brakes on a disc only frame
9 Users
Hi All,
Just upgraded to a new frame and in the process of moving everything over. I have cable disc breaks (BB7s until i upgrade) but the frames mounts for the rear brake are for hoses only.
Can i get an adpter to put into the hose mounts so i can mount the cable for now?
Joe
Posted : 13/05/2009 8:00 pm
just lash them on with zipties for the time being
Posted : 13/05/2009 8:03 pm
can you not thread the cable housing through the hose mounts. will require a full length housing if you do not already have it.
Posted : 13/05/2009 8:05 pm
You [i]can[/i] get adapters, but I'd just buy a full length outer and have done with it.
Posted : 13/05/2009 8:22 pm
Just run full length housing, much better.
Posted : 13/05/2009 8:30 pm
Full length outer - better winter proofing.
Posted : 13/05/2009 8:49 pm
Cheers guys, didnt know if putting a full outer on it might put a bit too much resistance on the cable pull, guess i over lube it should be fine. See what i can do tomorrow.
Note to self - buy hydrolics soon 🙂
Posted : 13/05/2009 9:06 pm
 Bez
I always use full outers and never bother with lube. No worries.
Posted : 13/05/2009 9:07 pm
Full length outer is just fine. I'm running that on my Kona and it's still the original cable (that'll be over three years old now). Don't bother with the lube - it just attracts dirt.
Posted : 13/05/2009 9:08 pm
Full length outers work really well.
A cheaper 'upgrade' would be to get some Avid Full Metal Jacket housing to replace the long straight runs of your cable housing. They make a real improvement to the brake feel, at least with the road version of Avid BB7s (maybe less so with the longer cable pull of the MTB ones though).
Posted : 14/05/2009 7:07 am
do not lube up the cable/housing. the housing has already got ptfe type slippery stuff.
lube just bungs it up.
Posted : 14/05/2009 11:41 am
Had BB7's with full length outers on my inbred for ~5-6 years and liked them so much (untouched in that time except for new pads) that I've moved them to my Blur and bought the same again for my 456.
Work a treat.
Posted : 14/05/2009 11:59 am
Cheers all, the very helpful LBS gave me a couple of little inserts for the hose mounts that allowed it to pull the cable as normal.
They gave them to me for free also so a shout out of kudos to Michael Vaughn in Kenilworth, decent bunch of chaps. Note to self - must procure next upgrade from there.
JB
Posted : 17/05/2009 5:05 pm
