Buying bits for 1x1...
[Closed] Buying bits for 1x10 conversion - help please?
I want to convert my 2x10 Camber Evo (it's the 2014 basic comp model) to 1x10. Never done anything more complicated on my bike than changing pedals.
It's got a SRAM X9 Type 2 mid-cage RD, and according to the spec online, the crankset is "Custom SRAM S-1250, 10-speed Trail double, PF30 spindle, S: 170mm, Others: 175mm".
I know I need one of these: http://www.chainreactioncycles.com/race-face-narrow-wide-single-chainring/rp-prod109723 - I'm going to get the 32T one with 104mm BCD.
I am also aware that I may need some new bolts for the chainring, and possibly a chain guide - but I am not sure which chain guides might work or if they're even needed.
Can any helpful soul point me in the right direction?
Cheers then.
Posted : 10/09/2015 11:03 am
If you are using a N/W chainring, then most likely you will not need a chainguide.
Plenty do not use a chainguide at all.
I personally use a top guide only. A Blackspire trail guide, just for a bit more security and a 'Taco' guard included.
[url= http://www.chainreactioncycles.com/blackspire-trailx-1x-chainguide/rp-prod112083 ]Linky[/url]
Chainring bolts you possibly may need. The N/W rings tend to be thicker so sometimes need a longer bolt.
If you choose a 30 tooth N/W Raceface ring as pictured, you actually only need one half of the bolt pair, as the chainring itself is threaded and the bolt screws directly into that.
Posted : 10/09/2015 11:07 am
Thanks for that. I'm gonna get the 32t one I think, I have managed OK just using the 36t ring for the last couple of months as a dress rehearsal.
I've got that Blackspire guide in the basket too, I am very suggestible.
Will these bolts do the job if I do need longer ones?
http://www.chainreactioncycles.com/race-face-outer-ring-bolt-set/rp-prod15231
Posted : 10/09/2015 11:25 am
I converted my Alpine 160 to 1x10 a while back using a bundle from CRC - very happy with the results. I had to get two extra things that I hadn't accounted for - the longer chainring bolts that you've already mentioned, and also a new connector link for the 10-speed chain to account for the slightly different link length. With the old 9-speed link the chain kept dropping off my chainring.
http://www.chainreactioncycles.com/kmc-chain-connectors/rp-prod25439?gs=1&gclid=CjwKEAjw1MSvBRDj2IyP-o7PygsSJAC_6zodcc7YDj2SQJaaOxKXPdG83yQZk6uHbo8jaefgRfKQEhoC5s7w_wcB&gclsrc=aw.ds
I didn't fit a chainguide but kept a blackspire on on standby just in case, but the combo of the clutch mech and n/w chainring has done a great job!
Posted : 10/09/2015 12:14 pm
You may not need that at all. Maybe try without it first, though it does offer some underneath protection too.
Posted : 10/09/2015 12:24 pm
