does anyone know where i can find any pdf's or vids anywhere?
i can't seem to find any
It's really so simple there's no need. Just knock out the qr adaptors and then it's all set for 20mm. It really is that easy.
rear hub not front. so bearings etc need changing AFAIK
Doh! Sorry. Should have read properly!
The QR set-up uses 6902 x2, 6001 x 1 & 6002 x 1
The 12mm set-up uses 6902 x 3 & 6002 x 1
Basically the 6001 bearing needs replaced with a 6902.
I am 95% sure it's the outside one on the non-drive side - whatever, it's the one that the 12mm axle won't go through.
Basically
- lever off the "QR" spacer on freehub side
- freehub body should just pull off - do it inside a carrier bag to catch any escaping pawls and springs)
- knock axle through from drive side
- knock the new bearing onto the disc side of the new axle
- knock the axle/ bearing into the hub shell and ensure everything is seated right (if you don't have the Hope drifts you can improvse with a socket set)
- push on the freehub (you can use the seal to hold the pawls and springs in place; locating the hub should seat the seal anyway)
- put the drive side spacer in place (if there is one, can't quite remember and it's too dark to check)
Bob is yo mamma's brother.
many thanks indeed, i'll hopefully get the stuff through on wed/thurs so i'll l et you know how i got on. ive done a full bearing change on it a few months back so it'll all come apart much easier than it did then hopefully!!
