Building wheels wit...
[Closed] Building wheels with used hubs
 D0NK
Rebuilding my rear wheel, the flange/spoke holes are slightly deformed from the previous build so do I reuse the same holes as before ie spokes inside/outside the wheels the same formation as before
OR use the alternate spoke holes so spokes are poulling against a non deformed section of the spoke hole/flange?
I [i]was[/i] going to do the latter - use alternate config, but I put the first spoke in and it doesn't seat too well, will it 'pop' into place under tension or should I go back to original configuration?
Posted : 18/07/2010 6:01 pm
Supposedly you should reuse existing notches...
Posted : 18/07/2010 6:12 pm
I would always reuse the hub in the same way. They can creak if built the other way though I doubt it actually makes any functional difference.
Posted : 18/07/2010 6:28 pm
I would reuse the rim in the same way as before too.
Posted : 18/07/2010 7:21 pm
