Building advice ple...
[Closed] Building advice please. Temporarily filling a hole where a door was.
[#5344944]
We need to rebuild our porch.
Taking it down removes the secure external door and exposes the non secure internal door.
That internal one is a narrow space, too narrow to fit an external door.
How do I keep the house secure during construction?
Is timber bolted over enough or do I brick it up?
Any other options?
Thanks.
Posted : 19/07/2013 9:52 am
2 pieces marine ply with timber spacer sandwiched in the middle. Coach bolts through all 3 pieces with the nuts on the inside. I'd do this top middle and bottom.
Posted : 19/07/2013 10:56 am
diawl2's way is the standard method. Should be pretty safe. Depends if the building is in a rough part of town. Might also be worth checking with your insurers. We are having some work done and they have specified a few thing regarding security
Posted : 19/07/2013 11:04 am
I rescued from the street skip a steel door used when boarding up council houses, and then bolted as suggested above.
Posted : 19/07/2013 11:12 am
