Broken Bottom Brack...
[Closed] Broken Bottom Bracket Shell
Had a creaking bottom bracket so replaced PF BB only to find that the aluminium BB shell is fractured where it covers the seat tube. It also rotates within the carbon frame. I presume that the shell should be a tight fit in the frame.
The shell isn't a complete cylinder. There are large cut-outs where the seat tube and down tube are. Drawing of shell attached (it is still in the frame but I've drawn it as if it has been removed - should have taken photo but forgot and have now fitted new BB).
Any clues on what to do? Can I replace the shell? Can I make it structurally sound again? Will a carbon frame repairer be able to fix it?
BB shell showing damage and how it rotates
Posted : 14/06/2020 8:02 am
[url= https://t43.pixhost.to/thumbs/202/151743045_img_3112.jp g" target="_blank">https://t43.pixhost.to/thumbs/202/151743045_img_3112.jp g"/> [/img][/url]
Posted : 14/06/2020 8:03 am
See if you can get a replacement frame under warranty?
Also, that picture hosting site has some "interesting" ads. Are they responding to your browsing history or mine?
Posted : 14/06/2020 8:17 am
Thanks for the idea - the bike is 2013 model so well out of warranty. The picture hosting site was the first I could find that was easy to use and didn't need the rigmarole of another username/password - perhaps this is why the ads server are somewhat dubious.
Posted : 14/06/2020 10:53 am
https://imgur.com/f3ub2Uv
Here's the picture from a less dodgy hosting site!
Posted : 14/06/2020 2:49 pm
I had a slightly similar issue and glued mine back in, not ridden the bike much since tho.
I think there are a few folk with knowledge around...
Posted : 14/06/2020 8:46 pm
Thanks @cynic-al. Can you remember what glue you used? Was it one specific to carbon material?
Posted : 15/06/2020 10:44 am
