Brake turkey warble...
[Closed] Brake turkey warble with new wheelset
Hi, got a really annoying problem, been riding a 29er Enduro for 3 years ish now running 2 sets of cheap superstar wheels with no problems. However I've just purchased a set of magic crossmax xl wheels and ive had terrible "turkey warble" when braking causing horrendous noise and vibrations through the frame. It was so bad I think it caused the rear hub to fracture and fail. I've had a new set on warranty but these have started to do exactly the same thing. When I put my other wheels on it dissappears completely. I've read about a wayto fix it by taping the rear of the pad so I'll try this tomorrow but has Anybody any ideas how to cure this.
Thanks
Posted : 08/03/2016 11:51 pm
FYI, I'm using zee brakes with 203mm rotors f&r.
Posted : 09/03/2016 5:14 pm
Are the rotors the same?Ive had a similar problem when the disk braking surface was smaller than the pad surface and the pads were catching on the rotor 'spokes'
Posted : 09/03/2016 6:39 pm
Yes that same discs on both wheelset. I put metal tape on the rear of the pads which seems to have made it slightly better but it's still there especially when wet. I took the sintered pads off ages ago cos they were unbearable with the mavics. Now running shimano resin pads. Anybody know if "floating" rotors would help???
Posted : 12/03/2016 9:15 am
Floaters won't help. Ime.
Try a dab of copperslip on the back of the pads after thoroughly cleaning the discs with isopropyl alcohol. Worked for me.
Posted : 12/03/2016 9:19 am
I had a similar problem with a rear Zee brake.Changed from a 203 rotor to a 180 and it cured it.
I believe it's something to do with vibration frequencys.
Posted : 12/03/2016 9:20 am
its one of those things unfortunately?
certain brake systems on certain frames or wheels cause a harmonic resonance
seen this before on a number of Trek and Devinci full suspension bikes, the cure was normally switching to an organic brake pad or different brake system
Posted : 12/03/2016 9:24 am
