Brake mount woes, i...
[Closed] Brake mount woes, is this right?
[#4078375]
Ok can someone please give me advice on this, should this mount/caliper be running this close to the rotor?
I think somethings bent... :/
Posted : 17/06/2012 11:21 pm
Your caliper is not central - centralise it and it should be a bit more gap but so long as nothing touches its fine
Use the two part method fro the hope site to centralise the calliper - its works well
Posted : 17/06/2012 11:23 pm
 GW
IS mount/adapter looks fine but as TJ says, your caliper looks to be positioned too far inboard
Posted : 17/06/2012 11:27 pm
Ok I've adjusted it slightly away from the bike.
But the mount is positioned fine?
was this the method?
(unadjusted, mount photo)
Posted : 17/06/2012 11:38 pm
I use the method shown in the video to centralise my calipers so you should be fine.
Posted : 18/06/2012 6:50 am
I've never found the 'squeeze the lever method' to be particularly accurate for centring my calipers...I find it easiest to remove the pads, then align the caliper by eye.
Posted : 18/06/2012 6:56 am
This. For two reasons.
Firstly, if you loosen the bolts, the tension in the hose from the fluid pressure twists the caliper; then, when you have it slightly tightened, it's often easier for the caliper to bend the rotor to its position than otherwise.
I found align one side of the caliper, tighten half a turn, align the other, half a turn, then tighten both.
Posted : 18/06/2012 9:39 am
* is the rotor true? It only takes a slight warp in the rotor for this to become an impossible task (but still perfectly rideable). Don't assume a new rotor is true, I've had to send 2 in a row back to the online shop I bought them from.
* save your sanity and know when good enough is good enough - unless all the parts are 100% new and bang on, the set up never will be, end even then it'll start to degrade a tad with riding.
It's a bit of a judgement call as this is the interface between theoretical in the lab engineering, and the crufty jaggy entropy-dominated real world.
The acid test is, with decent power in the brakes and the pads pumped out, you can spin the wheels with no drag and the braking is smooth.
Posted : 18/06/2012 10:01 am
Just look at the vids on the hope site for the best way to centre a caliper - first you get the caliper central then you make sure the pistons are centralised and move evenly
Posted : 18/06/2012 11:21 pm
