retro83 - Member
Not taking the piss, just thought it was funny appearing at this point in the thread.
What you're referring to is brake squat (compression), not brake jack (extension). Jack as in 'jacked up', not 'jack hammer'
The reason people get confused about it is because it is damned confusing!
http://www.rotorburn.com/forums/showthread.php?35572-quot-Brake-jack-quot-an-explanation.
I didn't read that I don't have time, but, brake jack is definitely compression not extension.
Brake jack and brake squat are the same thing.
No, it isn't. Maybe this is why there is so much confusion around on the topic.
http://trekmountain.typepad.com/king/2007/08/abp-explained.html
I was wrong, it is in fact just stiffening of the rear suspension under braking reducing suspension movement, nothing to do with compression or extension.
Either way ABP didn't noticeably work compared to the Five and that is what they are trying to address.
Its called brake jack because it gives the bike a jack hammering effect over bumps, its nothing to do with the suspension extending
Got a source for that? Cos everything I read says otherwise.
The fact your Trek felt the same as your Orange just goes to show suspension interacting with caliper braking forces is not important. The roughness you feel is caused by your wheel trying to slow down.
That even happens in a car. Brake hard over bumps and it makes them feel really rough. THAT is unavoidable.
Snippet from Titus website:-
[b]4 BAR LINKAGE DESIGNS: AKA HORST LINK[/b]
There’s never been a more hotly contested suspension design on the market then the 4-Bar linkage design with the Horst Link. This design has been around only slightly longer then the original Outland VPP, but its instant success and many attributes have made it the most valued and fought over suspension design in the world. The original design was developed by Horst Leitner at AMP research. The driving goal behind the design was to isolate braking forces from affecting the suspension performance. The first generation Horst bikes did not stiffen up or lift (brake jack) under hard braking. They were and still are to this day “fully active”. The icing on the cake was that the original bikes pedaled better then anything else at the time.
Marketing bumph ^^^
I should use my rear brake more so I can join in these exciting debates
Well so far the replies have shown that:
1/it's caused by the suspension compressing during braking
2/""""""""""""""""""""""""""""" extending """"""""""""""
3/ it's got nothing to do with the above
glad that's all clarified then ! 🙄
I'm right - ignore everyone else.
He doesn't have a clue, and I give up.
It's caused by bad braking and useless riders, I'm so good it never happens to me.. 😯
Doesn't it just encourage you to choose a better place to brake rather than slamming them on in the middle of a rock garden?
I definitely do 🙂
If you don't brake on the rough bits how else can you make the braking bumps bigger.That is the idea is'nt it?? 😀
