Brake hose frame gu...
[Closed] Brake hose frame guides - too large for brake hose.
just bought a frame which has brake hose guides that are open ended with no zip-tie hole on them.
My brake hose is thinner than the guide, so it doesn't stay in the guide.
How do others over come this? Is there little clip adapters to hold the brake hose that you can clip around the hose that fills the gap between the thin brake hose and large frame guide?
cheers
Don
Posted : 25/05/2010 9:53 am
I just wrap a bit of electrical tape around the hose where it presses into the guide.
Posted : 25/05/2010 9:57 am
You want some of these
I've been looking for some myself so if anyone knows of a source, I'd appreciate the info
pix
Mine has that. I luckily had some spare 'bungs' from my old trek frame which worked. They are plastic spacers which are split down the middle so the hose can go through. Very difficult to explain
Personally if i lost them i would just use electrical tape the same colour as the brake hhose. Wrap it around until it is sufficienct thickness to be held in place.
The part you are looking for is something you will get from a lbs or M componants
Posted : 25/05/2010 9:58 am
uplink - thats exactly the kind of thing I was looking for.
GeeWavetree - will do shortly
Balls, too slow
Posted : 25/05/2010 9:59 am
jagwire apparently do the clips pictured above, but i cant see anywhere in the UK that sells them.
Posted : 25/05/2010 11:00 am
my spesh stumpy has guides like that - i got an lbs to fit some avid brakes and they used some of those split bungs. just ask at a local shop - radical thought i know! ๐Ÿ˜ฎ ๐Ÿ™‚
Posted : 25/05/2010 11:07 am
