Bottom out damper b...
[Closed] Bottom out damper blocks in fork lowers sliding about?
Hi all,
Rockshox Totems - the yellow rubber bottom out damping blocks are sliding up and down when I turn the fork upside down. Tried pressing them down in place at the bottom of the lowers with a bit of pipe, no luck, still slide up.
Is this normal?
Only asking as I've taken them to bits before etc, and never noticed the blocks sliding around after reassembly.
Ta, Duane.
Posted : 12/04/2012 3:27 pm
Hi
I belive its normal. My pikes were the same and never suffered any ill effects
Posted : 12/04/2012 4:13 pm
Yeah normal, my Boxxers did it too.... then I binned the bumper
It's only a problem when you service them as you have to make sure that it's on the damper/spring rod when you're screwing everything back together.
Posted : 12/04/2012 4:22 pm
Thanks.
Posted : 12/04/2012 4:25 pm
