Bottom bracket star...
[Closed] Bottom bracket starting to go?
5 Users
Can you please tell me what the symptoms are when a hollowtech bottom bracket starts to go?
Getting some odd noises from that area which started before changing my chain, crank set, cassette and jockey wheels.
Posted : 13/03/2012 6:54 pm
Bearings making a grinding noise or you might feel some play when you grab the crank arms and try rocking them side to side.
Posted : 13/03/2012 11:25 pm
Sound effects usually. They have to be very seized before it's very obvious when pedalling. If in doubt, pull the cranks out and give the BB a poke, you'll feel it.
Posted : 14/03/2012 12:16 am
take the chain off and spin the cranks, you hear it if they are on the way out, they make a sort of grumbly sound.
Posted : 14/03/2012 12:27 am
Thanks very much.
Posted : 14/03/2012 10:27 am
If the cranks move side to side doesnt mean the bearing are gone i dont think, it just means that the cranks are loose most of the time and just nipping the crank bolt(black nut) up a tad to remvoe play works.
tbh i hae had my hollowtech for about 8 months now with no issues(mainly commuting),
Posted : 14/03/2012 3:01 pm
