Bottom bracket leng...
[Closed] Bottom bracket length issue - calling tech experts!
I just acquired a yeti arc frame with a BB shell of 73mm. I want to run a middleburn duo crank with two chain rings, with a square taper BB.
What's the ideal BB axle length to get the right chain line?
Thanks for your help!
Posted : 04/03/2010 12:37 pm
Hi there.
Middleburn site recommends 113mm for square taper and ISIS BBs.
So you should buy the 73x113 size.
http://www.middleburn.co.uk/tech_faq_cranks.php
This should put the middle of the chainrings (in your case between the pair) in line with the 5th sprocket on a 9-speed.
This may not be ideal if you are always in the lower ring on large sprockets, but is the official 'neutral' fitting.
Note CRC have a cracking deal on the Crank Brothers Cobalt ISIS BB at £25 and it has a 5-year warranty according to the CB and UK Importer's websites.
Posted : 04/03/2010 1:04 pm
 69er
BB axle length is dictated by the chainset. BB with is obviouslt the chain size. It doesn't matter what frame you're fitting it to..
73 x 113mm is correct.
Posted : 04/03/2010 1:08 pm
