Bottom bracket conf...
[Closed] Bottom bracket confusion
So I've decided to try and build a bike for the first time. Bottom bracket standards/widths etc are confusing the bejesus out of me.
I'm going to buy a SC Chameleon frame. On the SC website the only info about the bottom bracket shell is "Bottom Bracket: Standard". I know it takes a threaded BB but I don't know what width.
I am taking my 2016 Trek Stache 9 to bits, and going to re-use what I can. It has a 92mm wide BB shell. This is called "BB92", right? It has Sram X1 cranks.
I'm confused about:
1) What BB do I need to buy to fit the new frame (SC Chameleon)?
2) Will I be able to re-use the cranks from my Stache? Does that affect what BB I buy?
Posted : 05/01/2018 3:30 pm
You need a SRAM GXP external cup bb (or compatible) to use your current crankset.
Posted : 05/01/2018 4:59 pm
Knowing Santa Cruz, it'll be a "standard" 73 mm wide threaded bottom bracket shell. There are all sorts of converters out there to let you use cranks that are designed for non-threaded bottom brackets (like your cranks seem to be). Just make sure you get the right adapter.
Posted : 05/01/2018 5:10 pm
Hope threaded BB plus the adapters should fit I think. Give Hope a call for 100% truth!
Posted : 05/01/2018 5:14 pm
Do your X1 cranks have a 30mm axle or 24mm axle?
Posted : 05/01/2018 5:16 pm
Definitely check the crank spindle before buying a B.B. for it.
But yep, SC have a 73mm English thread B.B. shell.
Posted : 05/01/2018 5:23 pm
I think the op would have struggled to get a 30mm axle through a PF92 bb so I assumed it was a GXP crankset.
Posted : 05/01/2018 5:31 pm
Thanks all! The existing BB says "GXP" on it, so that settles it. Sram threaded 68/73mm GXP BB on order from CRC!
Posted : 05/01/2018 6:55 pm
