Hi guys.
Looking for some help/advice please.
I have a giant tcr advanced pro I 2017 road bike .
And iam looking to replace the stock bb which I have in already which is a shimano sm-bb92-41b
On a 86mm bottom bracket shell press fit 30 to a 24mm axle.
Can anyone recommend a better quality bb to use which is the best one for your money and basically put in and forget about with a issues with creaking
I have been looking on the website and there's just two many out there and basically no idea which is best.
Thank you hopefully someone can put me in the right direction as soon as possible.
Many thanks in advance.
The frame is BB86 / PF41 - the Wheels Manufacturing BB86 Thread Together has two halves that screw together for better bearing alignment and doesn't need a press to install - makes it easier to periodically remove and clean / relube for a creak-free existence.
You mention PF30 in your original post - has nothing to do with your current set-up, its a different BB standard.
Dovebiker.
Thank very much for your feed back got say great advice and I will definitely look into this kind of bottom bracket hopefully it will solve my issues that I have.
Thank you once again.
