Bottom bolt in pike...
[Closed] Bottom bolt in pikes non drive side leaking and keeps turning!
[#7568835]
Found the leak by chance. Tried to tighten it up but I think I overdid it. Not I can't get the bolt out.. It's loose to turn but it keeps turning. Grey oil and bits of aluminium are starting to appear too!
Is this a job for a shop? Or Loco?
Posted : 09/01/2016 11:30 pm
If you have a decent lbs try that first perhaps? Sounds a little knackered unfortunately, I did a similar thing with some Fox 36s and snapped the bolt off the bottom of one of the legs by over-tightening it. It needed a new Talas cartridge which wasn't cheap. You might need the internals replacing on that leg? I'm not 100% what Pikes are like internally.
Posted : 09/01/2016 11:53 pm
Oh ekk
Posted : 10/01/2016 12:02 am
 LoCo
32 or 35mm pike and which spring system does it have?
Posted : 10/01/2016 12:44 am
35mm stancions. Rct3 Solo air.
Posted : 10/01/2016 1:35 am
I had this happen with mine. They eventually went back to Fisher and were replaced under warranty
Posted : 10/01/2016 11:05 am
I've changed the or shaft to 160mm. I hope that doesn't effect the warranty. Also the rebound adjust dial is frozen now.. May be because there is a bitter edge from me trying to strip things apart!
Loco. What's your turn around time this coming week or so?
Posted : 10/01/2016 1:04 pm
 LoCo
Hi Dan,
can do stuff this week coming, stud sounds like it's rotating in the leg possibly. Happy to have a look at them for you and deal with warranty return if applicable too.
Posted : 10/01/2016 7:31 pm
Loco..
Cheers.. They're an Evans purchase 22 months ago. Ill sort out shipping them to you tomorrow. Do I fill your online form in and ship as per your we sight instructions?
Posted : 10/01/2016 11:46 pm
 LoCo
Hi Dan, yes please and I'll mail you to confirm everything. Cheers.
Posted : 11/01/2016 11:06 am
