Boring I know but r...
[Closed] Boring I know but recommend a (quiet) chainstay protector
[#11163628]
So I've been using mastic tape as a chainstay protector for a couple of years now and whilst it's good it's a pain to put on and remove, and it looks old pretty quickly so needs replacing fairly often. But it does stop chips and keeps noise down well.
I'm wondering if there is something out there that is maybe a little more robust than mastic tape and quietens the bike? Frame/Heli tape are good as they are robust so don't need replacing but they won't really quieten the chain slap noise. And I don't like the neoprene wrap around protectors.
Does anyone have any recommendations for something I could use? What do others use?
Posted : 28/04/2020 2:45 pm
old inner tube
Posted : 28/04/2020 2:55 pm
Yep, inner tube.
Posted : 28/04/2020 3:00 pm
I've always just used old inner tubes as well.
Posted : 28/04/2020 3:01 pm
Heavy duty fluffy velcro tape, cut to shape and stuck on. Lasts yonks.
Posted : 28/04/2020 3:09 pm
Inner tube fourth-ded. Wrapped around like a tennis racquet grip.
Posted : 28/04/2020 3:25 pm
Blobs of CT1 or similar have worked well for me. Cheap, easy and effective. Much tidier than scabby wraps imo.
[url= https://live.staticflickr.com/7861/45775043885_c11a5dc40d_5k.jp g" target="_blank">https://live.staticflickr.com/7861/45775043885_c11a5dc40d_5k.jp g"/> [/img][/url]
[url= https://live.staticflickr.com/7812/32815285548_186f0d5c93_5k.jp g" target="_blank">https://live.staticflickr.com/7812/32815285548_186f0d5c93_5k.jp g"/> [/img][/url]
Posted : 28/04/2020 3:26 pm
if you say so 😬
Posted : 28/04/2020 3:32 pm
Erm, looks like the world smallest dog has done a series of dumps on the chain stay........and doesn't protect underneath.
Old inner tube wrap here too. May not be the prettiest but is cheap and effective and could be considered to be some form of recycling.
I've also cut loops from the centre tread of old tyres. Looks a bit gothy but also works well.
Posted : 28/04/2020 3:38 pm
I'm another inner-tube user, but you might also consider spiral cable wrap: https://www.amazon.co.uk/Spiral-Cable-Wrap-6-60-black/dp/B002M2JV8Q
Posted : 28/04/2020 3:54 pm
Thankfully we're past the days of a scabby old inner tube zip tied in place, or a baggy lizard skins bit of neoprene velcro'd on.
I would buy one of the new style rubber ribbed ones & use a craft knife to shape it specifically to your chainstay.
The Scott Ransom one works well for that. I have it on top of the standard Yeti one on my SB130 to make it silent 🙂
Posted : 28/04/2020 3:58 pm
good shout @HobNob
Posted : 28/04/2020 4:09 pm
 K
3M 2228 Rubber mastic tape and cut it to the shape you want, stick it on.
Posted : 28/04/2020 4:14 pm
Hob Nob
Member
Thankfully we’re past the days of a scabby old inner tube zip tied in place, or a baggy lizard skins bit of neoprene velcro’d on.
I totally agree with this, zip tie-ing an old inner tube isn't for me, I want something more attractive than that, even if it would do the job ok. Will investigate the ransom protector.
K
Member
That's the stuff I've been using but I find it ages quickly and looks knackered after only a few rides.
Posted : 28/04/2020 4:25 pm
Is this the Scott one in question?
Posted : 28/04/2020 5:00 pm
I had to scramble for something for my Solaris when mounting an archer d1x and ended up using synthetic tennis racket grip overwrap. I was not prepared to go the inner tube route.
For a better solution on a project bike, I was going to order this...
Raaw ribbed
But postage to canada is currently shitty so I haven't.
Looks more 'generic' fit wise than the one on my ransom.
Posted : 28/04/2020 5:04 pm
The Raaw one is available closer to home too: https://www.bike-components.de/en/RAAW-Mountain-Bikes/Chainstay-Protector-p75876/many
Although saying that the postage is also terrible
Posted : 28/04/2020 5:14 pm
Self amalgamating tape, or whatever it's called. wrap it round and tape up each end nicely with a bit of insulating tape.
Easy to install and easy and clean to remove.
Cheap as chips as well off ebay.
https://www.ebay.co.uk/itm/Self-Amalgamating-Repair-Tape-10m-Rubber-Waterproof-Sealing-Insulation-19mm-25mm/352427712954?epid=2255475993&hash=item520e5421ba:m:m5nC-2wh-KWRtu6rocZAszw
Posted : 28/04/2020 5:22 pm
I like mastic tape too
Posted : 28/04/2020 5:40 pm
 core
Every, single, time.
You don't have to bodge something or invent a method using DIY store products - you can buy a thing called a CHAINSTAY PROTECTOR - it's specifically designed to protect your chainstay, usually made from neoprene, so cushions the chain and keeps things quiet, is available in a range of sizes, colours and designs, and is removable (due to the velcro fastening) to clean!
They cost anywhere from a HUGE £5 upwards and are virtually indestructible, I have a couple that are years old, have been on multiple bikes in all weathers and still do their job like they did on day one.
Posted : 28/04/2020 5:49 pm
I use either an old inner tube or self amalgamating tape.
Posted : 28/04/2020 5:50 pm
1" gorilla tape, pulled tight so it follows the curves of the chainstay. Snip it to rounded ends with scissors if you fancy. 2 layers if you fancy moar quietness. I might try snipping a 1/8th inch strip of inner tube to run along the top/centre underneath the tape next time I do it. but I don't know when that will be! Lasts for years.
Posted : 28/04/2020 5:55 pm
nedrapier
Subscriber
1″ gorilla tape, pulled tight so it follows the curves of the chainstay. Snip it to rounded ends with scissors if you fancy. 2 layers if you fancy moar quietness. I might try snipping a 1/8th inch strip of inner tube to run along the top/centre underneath the tape next time I do it. but I don’t know when that will be! Lasts for years.
I quite like that idea. I have a whole load of little rubber strips so I could cut lots of little bits to go under the gorilla tape to give cushioning and to add to the shop bought look. Will hopefully look quite pro actually.
Posted : 28/04/2020 6:18 pm
These are great, spend a bit of time trimming to shape and secure with a cable tie each end to be double sure. Only thing is I don't know if they're still available
https://www.mbr.co.uk/reviews/products/csixx-chainstay-protector-review
Posted : 28/04/2020 6:21 pm
Premier Icon
core
Subscriber
You don’t have to bodge something or invent a method using DIY store products – you can buy a thing called a CHAINSTAY PROTECTOR – it’s specifically designed to protect your chainstay, usually made from neoprene, so cushions the chain and keeps things quiet, is available in a range of sizes, colours and designs, and is removable (due to the velcro fastening) to clean!
And crap at fitting in or around the complex ends of a full-sus chainstay. If I tried one it’d foul the chainring where it’s most needed
Posted : 28/04/2020 6:22 pm
core
Subscriber
Yeah, I have some of those in a box somewhere that I replaced with better solutions
Posted : 28/04/2020 6:54 pm
2228 Tape.
If it comes off you must be applying it to a frame covered in grease. I've never known anything with the same tenacity. I snapped the chainstay of my Intense and it was still held together by the single strip of 2228 that was on it.
Posted : 28/04/2020 7:26 pm
 LAT
This is an elaborate solution:
https://stfubike.com
Posted : 28/04/2020 8:10 pm
continuity
Member
2228 Tape.
If it comes off you must be applying it to a frame covered in grease. I’ve never known anything with the same tenacity. I snapped the chainstay of my Intense and it was still held together by the single strip of 2228 that was on it.
It's not coming off. It's sticks to the frame fine, I just find the surface attracts all the dust and dirt from the first few rides and never looks good afterwards
Posted : 28/04/2020 8:19 pm
Plenty of diy STFu's on the bike park made from fox 40 bumpers.
Posted : 28/04/2020 8:39 pm
Old inner tube
Posted : 28/04/2020 8:42 pm
As IHN says
attached with a one zip tie almost impossible to see it.
Posted : 28/04/2020 10:00 pm
A strip of inner tube along the top of the chainstay with self-amalgamating tape wrapped around. If you use black tape, the holes that develop won't show.
Posted : 28/04/2020 10:24 pm
As a slight aside - what glue for a glued on protector? Can think of plenty that would work, none that I’d want to use
Posted : 28/04/2020 10:49 pm
Chain Tamer
Brilliant widget thingummy.
Posted : 28/04/2020 11:43 pm
Druid
Just ordered one of these.
Posted : 28/04/2020 11:57 pm
That druid one looks good but my worry about these bike specific ones is that they're not guaranteed to fit other frames. Is the druid one flexible at all? Can it be trimmed? How does it fix?
Posted : 29/04/2020 11:40 am
When I was clearing my Dad's garage out, my first "mountain bike" was there. Before it went off to the bike recyclers I took off the shark's fin protector it had. I'm tempted to start using that.
The shark's fin was held on by small cable ties and an adhesive pad like car numberplates are held on by.
Posted : 29/04/2020 3:10 pm
I get very annoyed with the chain noise on the back of my bike, forgot I ordered one of the STFU's until it turned up! looks a good piece of kit.
I am waiting for this Eddie Master's VHS tape to arrive to try first.
Posted : 29/04/2020 4:36 pm
Self adhesive Velcro works well.
Posted : 30/04/2020 3:08 pm
Dunno. It's not been posted yet.
But, appears to be relatively 'unshaped' which would suit the BMC project I have going on
Posted : 30/04/2020 4:50 pm
Butyl rubber sealing tape
Posted : 30/04/2020 5:14 pm
fletch71
Member
That's my nuclear option, only thing short of filling the swingarm with foam that quiets a 224
Posted : 30/04/2020 5:29 pm
Slapper Tape
Posted : 30/04/2020 11:14 pm
Just ordered one of these. Will report back if it's any good. Half price at Cycle Surgery (who are closing down).
https://www.cyclesurgery.com/lister.html?q=Ams%20chainstay
AMS chain guard
Posted : 03/05/2020 8:52 pm
