Boost Chainring for...
[Closed] Boost Chainring for raceface cinch cranks - where can I buy them ?
11 Users
I'm looking for a boost specific chainring to go on some atlas cranks, (1x11) something like this:
https://www.competitivecyclist.com/absolute-black-race-face-oval-cinch-boost-direct-mount-traction-chainring
or this : http://www.chainreactioncycles.com/oneup-components-narrow-wide-cinch-boost-oval-chainring/rp-prod154615
but every UK retailer/website seems to out of stock - what am I missing? are people using standard offset rings successfully?
thanks, andy
Posted : 21/05/2017 6:28 am
Have a look on superstar ,what crankset is it for ?
Posted : 21/05/2017 6:34 am
One up do them and ship from Uk
Posted : 21/05/2017 6:42 am
I used a works components 32t oval cinch ring for my aeffect cranks on a boost bike and everything works well.
I have no idea if they're boost specific however.
Posted : 21/05/2017 6:43 am
I have just fitted this to my Jeffsy turbine cranks and all is good
[url= http://www.chainreactioncycles.com/mobile/blackspire-snaggletooth-cinch-chainring/rp-prod144515 ][/url]
Posted : 21/05/2017 7:32 am
Cheers all,
they are to go on an atlas chainset (2017 five)
Superstar only seem to do a standard offset : http://www.superstarcomponents.com/en/raptor-chainring-raceface-direct-mount-narrow-wide.htm
Works components say that their ring has a 50mm chainline - isn't boost supposed to be more like 53mm?.....but I guess it works for you mintyjim http://www.workscomponents.co.uk/works-components-oval-narrow-wide-chainring---raceface-cinch-fitment-1090-p.asp
I saw the blackspire one creagbhan linked to - seems to be the only one chain reaction say works with boost spacing, but I just wanted to make sure!
seems like a lot of rings will work but I didnt want to have to buy one to find out
thanks fellas
Posted : 21/05/2017 8:47 am
Raceface rings use 51mm chainline so only 1mm off the 52mm most boost specific rings use. I'd just use a standard raceface ring.
Posted : 21/05/2017 9:38 am
If you don't need maximum tyre/chain clearance (i.e. you are running 3"tyres) then a non-Boost crank/ring will work fine with a Boost hub.
Posted : 21/05/2017 9:43 am
If you are looking for a 34 tooth oval chainring then I have a absolute black oval that I fitted but cannot use as its too close too the chain stay.
Posted : 21/05/2017 11:28 am
thanks to all for the info 🙂
Rick - thanks for the offer but my legs need something smaller (30 round/32oval)!
Posted : 21/05/2017 12:05 pm
TBH I don't know exactly what the difference is, but, flipping the ring on my aeffect crank moved it out a good bit, it's an old trick for fatbikes but it'll do the same on any raceface crank.
Posted : 21/05/2017 12:18 pm
One up do 52mm boost cinch rings, I just bought one
https://www.oneupcomponents.com/products/switch-cinch
Posted : 21/05/2017 4:34 pm
 stuc
I'm using standard AB non boost cinch chainring with Boost frame Cotic Flare Max so it may be the case that you can run a non boost version
Posted : 21/05/2017 4:42 pm
1. Don't worry about Boost/non-Boost. Do you need clearance off the tyre or chain stay? If so, you need Boost. If not, you don't and you'll get a better chain line with standard stuff.
2. If you need a cinch compatible chainring try the absolute black oval. I'm loving mine and will be switching all bikes to them. If you don't like the oval, they'll swap if for a round one. You can't lose.
Posted : 21/05/2017 6:17 pm
