Bontrager tubeless ...
[Closed] Bontrager tubeless rim tape ?
I cant seem to find this stuff online, unless i am looking/searching for the wrong stuff, its the bontrager equiv of the stans yellow tape i am rambling on about, think its blue, where the hell do i buy it ?
Posted : 17/01/2011 9:25 pm
This is what you want,
http://www.pedalon.co.uk/acatalog/bontrager_rim_strip.html
It's for Bontrager tubeless wheels only though, can't be used with other rims. You will also need a valve and some sort of sealant, either Bontragers own or make your own
Probably get it cheaper elsewhere
Dave
Posted : 17/01/2011 9:35 pm
On my Bontrager's the tubeless strip was black, it was the standard rim tape that was blue.
Dunno what other brands are like but it was dead easy to fit. 🙂
Posted : 17/01/2011 9:48 pm
DaveL, Nah, thats not it, its the tape for sealing the spoke holes i was on about, folk have used it on stans rims instead of the stans yellow tape, its cheaper....
Thanks anyway !
Posted : 17/01/2011 9:49 pm
The Specialized stuff is blue but it's absolute crap compared to the Stans stuff
Posted : 17/01/2011 9:51 pm
Ahhhh, specialized, thats why i couldn't bloody find it ! Oh, not as good as stans then ?
Posted : 17/01/2011 9:55 pm
It's nowhere near as thick, sticky or strong as the Stans stuff and hence is far more likely to get wrinkled, come unstuck and subsequently leak.
Stan's is the proper stuff and works perfectly. It's not even that expensive really
Posted : 17/01/2011 9:57 pm
Yeah i bought some of the wider stuff for my flows, Mrs Tragic now has crests so need the narrower stuff, best just buy stans then by the sounds of it
Posted : 17/01/2011 9:59 pm
Crests should have the same width tape as the Flows, the 25mm stuff. Works better than the 21mm.
Posted : 17/01/2011 10:00 pm
I thought the 21mm stuff was specifically for crests ?
Posted : 17/01/2011 10:02 pm
Nope, it's for Olympic/Alpine rims mainly. Definitely use 25mm on Crests
Posted : 17/01/2011 10:03 pm
Just use the bontrager strips they work fine. I have a spare set of the asymmetric ones if you need them. I bought the wrong ones so these are just sitting around doing nothing all you need to pay is postage and packing costs.
Posted : 17/01/2011 10:25 pm
Got some of the 29er flavour + they seem to work OK
[url] http://www.swinnertoncycles.co.uk/Bontrager-Rim-Tape-Rimstrip-Asymmetric-Tubeless-26-Race-Lite.aspx [/url]
Posted : 17/01/2011 10:26 pm
I've just ordered that swinnerton 29er one. Anyone know for sure if it's the right one for a Bonty Mustang osb rim?
Posted : 17/01/2011 10:31 pm
Out of interest, what's wrong with insulation tape instead of stand yellow/ etc? Works fine with tubes so why not tubeless?
Posted : 17/01/2011 10:33 pm
I'll ask for you clubber 🙂 I use the Bonty strips on two sets of King Earl wheels with stans sealant, its fine.
Posted : 17/01/2011 11:00 pm
Ta. Can't really find out detail as to which one to use but the rhythm one seems much wider and isn't asym
Posted : 17/01/2011 11:04 pm
Craig will check your order in the morning clubber, make sure they are the right ones
Posted : 17/01/2011 11:17 pm
tragically1969, I've got a 10m roll of 21mm stans tape for sale unused £8 posted
Posted : 17/01/2011 11:52 pm
tragically1969, if it is Bontragers tubeless stuff you are after use their rimstrips suggested by DaveL, they fill the spoke bed by just the right amount and I have never had any bother inflating tyres (admittedly bonty tyres also) as it all just works. No other tape required, and yea, the blue stuff is the normal rimstrip.
Posted : 18/01/2011 8:45 am
Thanks snakebite - that's service 🙂
Posted : 18/01/2011 9:39 am
taking of wheels...
Posted : 18/01/2011 9:52 am
granny_ring, cheers, but matthew_h is correct, its the 25mm i need, just ordered a new roll.
Posted : 18/01/2011 11:14 am
Well they just arrived (excellent service, Swinnerton! Only ordered yesterday afternoon) - they do look right but it'd be good to have confirmation before I fit them.
Posted : 18/01/2011 1:10 pm
Fitted and definitely correct - a bit of work getting them fitted but in place and seem like a very good design though we'll see how they are in use. Had to pump the tyre up to 40psi to get the bead to fully seat but it seems nice and secure now.
Posted : 19/01/2011 12:57 pm
Did the second one today and that was a right faff. All sorted now but had to trim the rim tape slightly where the vale sits to get it to seal properly and it was an arse getting the strip into the bead hooks on the rim. Seems to be all secure now though.
Posted : 21/01/2011 4:19 pm
