Bolts for Absolute ...
[Closed] Bolts for Absolute Black 30t oval chainring 104bcd
When these are sold by Absolute Black they include the chainring bolts... but I got an eBay 'bargain' without bolts. Doh.
I want to mount it on an SLX double chainset 104bcd so, what would be the best option to buy... size and whether steel, aluminium or titanium?
Posted : 04/03/2019 1:11 pm
 Yak
Any single chainring bolts will do. But look for those that use a hex key fitting on both sides. Much better than faffing around with chainring bolt tools.
Posted : 04/03/2019 2:13 pm
Thanks. I thought the 30t 104bcd ovals needed a special mix to make them work.
Posted : 04/03/2019 2:22 pm
 Yak
Oh. Usually 30t on a 104 bcd will have built in threaded spacers. If that's the case then you only need a standard length chainring bolt, not the nut part.
Forget that. Sorry you are right. Specials for absolute black. You will have to contact them
Posted : 04/03/2019 2:26 pm
Thanks. Have to bite the bullet!
Posted : 04/03/2019 3:58 pm
I thought 30t was the min for a round ring on 104bcd...
and 32t was the min for an oval, for obvious reasons. Am I wrong?
Posted : 04/03/2019 8:18 pm
I fitted an AB oval 32t and used the same bolts as my previous round 32t, nothing special needed for the oval one.
Posted : 05/03/2019 7:51 am
I thought 30t was the min for a round ring on 104bcd…
I guess that's why it needs special bolts, as there wouldn't be enough space on the narrow bit for standard bolts. Maybe?
Posted : 05/03/2019 7:54 am
From the Absolute Black website in reference to 30T oval on 104BCD
*30T chainring has build-in 2.5mm spacers and threaded holes (M8 / M5) to accommodate this size on spider. It also comes with bolts and spacers in the package: 2x M8 aluminium bolts T30 torx, 2x M5 steel bolts T25 torx and 2x eccentric spacers. This is a patent pending solution.
Posted : 05/03/2019 9:14 am
good to know
Posted : 05/03/2019 9:34 pm
