Bolt-through workin...
[Closed] Bolt-through working loose on Revs.
Recently the front wheel has been getting wobbly after each ride and the bolt-through is becoming loose.
Not tight enough to start with or some other issue?
Posted : 23/07/2015 10:27 am
I've had the same thing with my Maxle. Was a little screw by the quick release that needed nipping up, sorted.
Posted : 23/07/2015 10:28 am
Ta. Will have a look at it
Posted : 23/07/2015 11:10 am
Hmmm... can't find a little screw on mine. I've given it a clean and tightened it up.
Posted : 23/07/2015 12:27 pm
Check a couple of things -
Are you using the flange to get the axle tight to start? Sounds like a daft q but we've had some customers who didnt realise thats what it was for.
How 'tight' is the lever to do up once the axle is screwed in? It should have some resistance, not as much as a traditional QR, but it should need some force to close up.
Posted : 23/07/2015 12:39 pm
As of 10 minutes ago it is "yes" to both of the above.
Don't know what it was like prior to this.
Posted : 23/07/2015 12:55 pm
