Bolt stuck in frame
[Closed] Bolt stuck in frame
[#3617115]
Managed to get a bolt stuck in my frame. It's an M8 'grub' screw that tightens the eccentric bottom bracket on my Swift.
Story so far:
1. Rounded the Allen head on it.
2. Soaked it in 3inOne's version of PlusGaz.
3. Tried a bolt extractor on it but it didn't shift, just enlarged the hole
4. Started to drill it out but the bit broke
Now I'm at a loss as to what to do. I'm reluctant to do anything else myself for fear of damaging the frame.
So who do I go to next? I'm based in SW London so local would be preferable
Posted : 28/01/2012 2:09 pm
 cp
Can you take a picture of what it looks like now?
Posted : 28/01/2012 2:18 pm
Penetrating oil is a waste of time. You need to shock it to break the bond in the threads; take a punch or something very strong and a big hammer and tap the bolt very sharply on the head, straight downwards. It will move after that.
Posted : 28/01/2012 3:48 pm
Hammer a good quality torx spline into it say a 3/8 drive on an extension,then, heat up the outer with a heat gun (thread part) & carefully turn it out! ,youll maybe need help to hold the frame etc, good tip here,dont use monkey metal bolts n cheap tools!
Posted : 28/01/2012 4:31 pm
MIG or TIG weld an alan key in it. The heating will probably free the threads anyway but you'll get a lot of leverage. Again, make sure it's a reasonable quality key not an Ikea special!
Posted : 28/01/2012 5:45 pm
Here's a picture:
[url= http://farm8.staticflickr.com/7157/6776675711_092ae8ef58_z.jp g" target="_blank">http://farm8.staticflickr.com/7157/6776675711_092ae8ef58_z.jp g"/> [/img][/url]
[url= [/url] by [url= http://www.flickr.com/people/paul_fulford/ ]paulfulford[/url], on Flickr
It's the top one. Nothing to grab with molegrips
Posted : 28/01/2012 5:49 pm
That`ll drill and then use a splined remover easy enough. 😉
Posted : 28/01/2012 6:03 pm
Cobalt drill & a Snapon easy out then clean it out with a tap job done,!
Posted : 28/01/2012 6:13 pm
A decent drill bit will work - start small and work your way up until you can get an extractor in, or until you can pull the threads out like a pigs tail.
Hth
Marko
Posted : 28/01/2012 6:14 pm
Well a happy ending! And a cautionary tale.
Took it round to a friend's who put his bolt extractor (Easy Out) on it. Just as we were about to give up it shifted!
Then he asked how the EBB worked. Simple I said just put an Allen key in and twist. Nada, nothing, that was seized as well :(. Fortunately a little persuasion and it shifted. We pushed it out and all the grease had dried out. Think I need to add regular EBB removal to my maintenance list. Bike was new about 15 months ago and I spent 6 months of last year abroad so it only saw light use.
Posted : 29/01/2012 8:01 pm
 JoeG
You might want to consider using anti-sieze compound instead of grease on the set screws and EBB hex bolts.
Posted : 30/01/2012 5:00 am
