The m-part mech on my 2012 Boardman CX is dead. It's a nine speed setup and I can't find anything to replace it with in the SRAM range (don't want another m-part, it was rubbish from day 1). Am I just lacking the requisite googling skills? Alternatively can I use a SRAM rival/apex 10 speed setup?
Won't a Shimano mech work? I'm using a 105 double front mech with Rival on my 10sp roadie.
m-part mech?
You mean the clamp, like this?
As above, I'd have thought a shimano would work.
From my experience a front mech is a front mech regardless of brand its only the rears that get into weird cable pull, I run a 9 speed on my 8speed cross bike and a 10 speed campag on my 9 speed road bike just make sure u get the correct fitment is reg the banding
Edit- if its a m pard band it may well be a microshift mech u have
I've got a 10sp Rival double, 34.9mm band-on in my spares box if you want to stick with Sram.
The mech not the clamp. Maybe it's m-part clamp and a microshift mech as RP says above.
Cha****ng - might take you up on that. Not really bothered about brand as long as it works. This is not the case with the current mech ๐
Just checked on mine and it's microshift.
Mine seems fine.
I wonder why they did that though - youd think getting a full groupset of SRAM would negate cost savings of one bit.
According to the current spec, they use a Microshift R74.
Thanks AS. Mine developed loads of play, think I got something stuck in it during an extremely muddy ride. Going to try a cheap/2nd hand 10 speed and see how we get on.
