Bleeding Simano
[Closed] Bleeding Simano
I am currently bleeding my deore disc brakes, however it is taking forever for the mineral oil to go down. It is however slowly, I hope, filling with the stuff. Only problem is......how do I know when it is full and ready and how much oil from the shimano bottle should I expect to use in filling up the brake (it's the front brake).
Posted : 15/11/2009 2:45 pm
 CTML
Shimano says it bleeds up to 2 brakes so i'm guessing down to half the bottle. It helps if the previous mineral oil is a different colour because you'd know when the new colour oil comes through its finished.
Posted : 15/11/2009 2:55 pm
You need to pump it thru whilst simultainiously opening and closing the bleed nipple at the caliper
Posted : 15/11/2009 2:56 pm
 CTML
Nice and short tutorial
http://www.5min.com/Video/How-to-bleed-a-Shimano-brake-system-66769651
Posted : 15/11/2009 3:02 pm
Definitely take the pads out first so as to be certain not to get fluid on them. I think I used a stack of coins to hold the pistons apart.
Posted : 15/11/2009 3:13 pm
 StuE
I use a syringe and bleed from the bottom up.
Posted : 15/11/2009 7:22 pm
2nd the above method, bottom up is the way to go, so simple and takes minutes per brake, it is idiot proof (don't try and prove that!)
Posted : 15/11/2009 7:34 pm
Done now. Thanks for the help everyone.
Posted : 15/11/2009 9:04 pm
