Bleeding Formula th...
[Closed] Bleeding Formula the one brakes
[#3422168]
I'm getting too much travel on the lever on the front brake
Tried bleeding it according to the formula instructions and a bit of air came out, but it didn't make much difference to the brake
Has anyone tried any other methods?
Maybe the avid method of bleeding?
Posted : 03/12/2011 2:22 pm
I ended up removing the wheel, pumping the brake a couple of times (to move the pads inwards) and then replacing the wheel. Just don't pump them too much or you won't get the wheel back in.
It's a real bodge job IMO, but the brakes don't seem to adjust to pad wear very well (especially if it's been a wet ride) so you'l gradually get more and more lever throw as the pads wear. This is the only way round it that I know of.
HTH
Ben
Posted : 03/12/2011 2:31 pm
Thinking about it.....I seem to recall that this method is actually detailed in the operating instructions from the manufacturers!
Ben
Posted : 03/12/2011 2:32 pm
so for every set of pads they need bleeding 2 or 3 times? 😯
Posted : 03/12/2011 2:41 pm
I don't do that though, I just do the bodge as described by Blob and then replace the pads when they are 3/4s worn.
Posted : 03/12/2011 2:48 pm
[url= http://singletrackworld.com/forum/topic/bleeding-brakes-how-to-an-idiots-guide ]Mr Nutt's guide is what you are seeking[/url]
Posted : 03/12/2011 3:06 pm
ahh, I misunderstood, I thought he was saying pump the brake then bleed them when the pistons had moved
and thanks wally
Posted : 03/12/2011 7:15 pm
