Bleeding brakes. Y...
[Closed] Bleeding brakes. Youuuuuu T@@@
[#8081698]
The usual. Cut hose, lose grip, flick Dot5 all over my front.
Set up to bleed, carefully draining fluid into a bottle. Suddenly theres fluid all over the floor. Yes, forgot to block the pistons, one of which has just popped out.
Posted : 29/09/2016 9:12 am
 jeff
We've all been there.... usually in the kitchen!
Posted : 29/09/2016 9:14 am
Next, mash the piston back in as squint as possible to damage the seals
Posted : 29/09/2016 9:18 am
Which is why I took the bike out of the workshop onto the paving outside for the bleed.
I like the simplicity of bleeding Hope, that you don't need a bleed kit or any special tools, and that I always seem to manage to bleed them well enough first time but it's always messy.
SRAM's pro bleed kit syringes on Guide brakes is so clean in comparison.
Posted : 29/09/2016 12:09 pm
Hope you picked up that piston, covered in sand and roadside detritus for extra T@@ttery points...
Posted : 29/09/2016 12:11 pm
Three magic words;
Bee
Bee
Seven
Posted : 29/09/2016 12:12 pm
or how about
want
to
stop
Posted : 29/09/2016 12:14 pm
Sounds about right 😮
Just be glad you haven't got Magura MT8s; for the love of christ I can't bleed the rear setup properly. Well, I can, and it works without problems for about 2 hours and then, usually about half way round a Marathon race, decides to go to the bar 😡 Plus the Magura bleed kit is rubbish.
+1 for the SRAM pro bleed kit 8)
Posted : 29/09/2016 12:19 pm
Pah!
Try replacing Slave cylinder on an LT77 gearbox and then try to bleed the clutch circuit!!! 😈
Posted : 29/09/2016 12:24 pm
Can't you just hang it from a nearby branch and flick it to get the bubbles to the top?
Posted : 29/09/2016 12:46 pm
J
Ha. Have been there - had a set on my Helius for a couple of years. Never got them to feel good -always mushy and when overheated they just lost power. Add to that the massively flexy lever and I was very glad to see the back of them.
Posted : 29/09/2016 2:05 pm
Been there, normally done the night before a big ride too so the bike is just right for the next day!
Posted : 29/09/2016 3:17 pm
 aP
Maybe you could take the top cap off the forks and turn the bike upside down as well 😉
Posted : 29/09/2016 3:59 pm
