blackspire stinger ...
[Closed] blackspire stinger as a ss chain tensioner?
Would it work? Anyone tried it?
Posted : 30/01/2011 11:50 am
BUMP.....
Posted : 30/01/2011 7:12 pm
Yep.
Seen one used on a Banshee paradox.
Posted : 30/01/2011 7:17 pm
Excellent, should give nicer lines than the deraileur ones
Posted : 30/01/2011 9:01 pm
I thought about using one on my ss, will it not be a nightmare to adjust when you need to slacken the chain remove wheel or make any tension adjustments?
Posted : 30/01/2011 9:17 pm
Wheel will come out no problem on vertical dropouts and you can get to the iscg bolts to adjust tension when there's no granny ring in the way.
Posted : 30/01/2011 9:21 pm
Ah, mine was bottom bracket mount not iscg
Posted : 30/01/2011 9:30 pm
Nice one Joe, i'd never thought of this. Perfick for if you wanted to quickly change to 1x9 aswell.
Posted : 30/01/2011 9:32 pm
I'll stick up some pics when it's done, and let you know how effective it is...
Posted : 31/01/2011 10:53 am
Paradox? Stinger?
Posted : 08/02/2011 2:17 pm
should be easier to get it out? as long as the dropout is vaguely forewards it'll just drop out?
Posted : 08/02/2011 3:09 pm
I had a problem with mine I took a knock to the tensioner when I was clearing some rocks, or not as the case was, it knocked it onto the chainset which meant pedalling was pretty much impossible. I was miles from anywhere up at Nant Y Arian and so had to fudge a fix which took ageees. For BB mount versions I guess this could always be a problem. Mine is not on my bike anymore if anyone is interested in buying one.
Posted : 08/02/2011 5:12 pm
