bit of a novice and...
[Closed] bit of a novice and need some help
ive just got my self a 2011 cube ltd team,
love the bike but find that its a bit low at the front,
my question is what would be the best way to rase it
Posted : 05/10/2010 11:54 am
Flip the Stem and add spacers if the fork steerer is long enough.
Posted : 05/10/2010 11:57 am
What MM said, and look at the position of the bars, if they are risers can you rotate them for more height
Posted : 05/10/2010 12:19 pm
Flipping the stem would give it a negative rise, ergo, lower so I wouldn't do that. Spec sheets for the bike says low rise Easton bars, so you could swap those for high rise versions and that will add about an inch.
Posted : 05/10/2010 12:29 pm
High rise bars+1, merlin have some good deals at the moment. I think a braced DJ bar (DMR wingbar?) has a fair bit of rise, depends on aesthetics too!
Posted : 05/10/2010 12:32 pm
If you've just got it, maybe give it a bit more time to get used to it. You might find its better for you once you've settled in to it a bit more. Cheaper too.
Posted : 05/10/2010 12:35 pm
Note to self; look at bike spec before offering useless advice regarding stem!! ๐Ÿ˜ณ
Posted : 05/10/2010 12:41 pm
thanks for all the advise guys think ill got the high rise bars
Posted : 05/10/2010 12:57 pm
