bikehike route to e...
[Closed] bikehike route to etrex 30 what format?
what is the best format for following a route? (cycle commute to work route)
gpx route
gpx track
gpxx route
tcx
txt
kml???????
Posted : 10/07/2014 9:31 pm
GPX track on a Garmin. Sometimes the routes have too many waypoints and the routes stops being marked out.
Posted : 10/07/2014 9:34 pm
thanks
Posted : 10/07/2014 9:37 pm
where do you save the track? memory card or on the garmin? and if in the garmin what folders?
Posted : 10/07/2014 9:45 pm
This. If you save it as a route, bikehike has the option to reduce the track points (in options, if I remember right). I can't remember how many you're allowed...if you keep it under 300 you should be OK. My first time using mine, I was 30 miles into my first century ride, in a place I'd never ridden before, when the track just ended! Always check the full route is there before I head out now!
Or save as track and don't worry about it. (Only difference I've noticed, is it doesn't beep when you;re on course)
Save it into the GPX folder on your Garmin.
Posted : 10/07/2014 11:35 pm
I use *.gpx tracks
I save them to a micro SD card (fits behind the batteries)
You need the same directory structure as the Etrex30, so you'll need a GPX folder on the card too
Big advantages for me:
Faster file transfers if you plug the card direct into your PC
Copy card content and keep a backup on your PC
Somewhere to back up your current track data to via BaseCamp (ie Etrex internal memory to PC)
Posted : 11/07/2014 5:44 am
