thinking of putting my bikes on a rack in the garage. Currently they hang by their saddles off a beam, but this is in the middle of the garage... Thinking of making a rack, made up of a couple of overhung (maybe 30deg off vertical) old rafters, with a number of bikes hung by their top tubes overlapping each other. I cant find any photos of this on google, and my sketching skills a bit rubbish. Anyone done anything similar?
......and I thought this was about a new Halifax-made that you'd bought etc
I have the pulley hoist things which allow walking space under the bikes, which work very well with a high ceiling.
the garage isn#t high enough. Its a sectional concrete garage with a lovely asbestos clad roof. The bottom of the roof frame is about 7ft. Which is nice to hang the bike by the saddle, but its a bit in the way. So thinking some form of wall hanger, but its not high enough for bike over bike style. So thinking of ways to overlap, but still get one out from the crowd.
Hang the bikes vertically, on-end by their wheels - attach a piece of 2"x4" timber across the roof beams - it needs to be just-over hub-height away from the walls. Simply screw-in some 99p plastic coated hooks from DIY store. Pitch the hooks about bar + tyre width apart and hang the bikes nose-to-tail
no issues with bleeding brakes or oils in forks when hanging for long periods the wrong way up?
None.
I was thinking that if you inclined that away from the wall at the top, and hung the bikes by the frame, you could get three into basically the same space as they could overlap vertically. The space behind could be where the spare wheels live.
Yes, could well do. I was limited for distance off the wall though (still need to lift them off), and my other bikes are grubby MTB's so live in the garage anyway!
^^ that looks good, how are the bikes held to the wall?
^^ erm... they're lying on the floor surely?
^^^What are the clips the pedal attaches to? Does it work for clips or flats only?
Looks great BTW
they are flat pedals that hook onto a Y shaped rubber coated hook thing - you can buy proper kits that do the same but cost about 40£km79 - Member
the floor is easier to keep clean on thewall as the dirt just falls off in a line at the bottom 😉
just googled for proper kit and saw these
might replace what I have with these
Not the most beautiul solution, but it fits 8 bikes side by side on a 2400mm length of wood with rubber coated hooks screwed into the wood. All in cost me about £10. Some of the bars on less used bikes are turned, and I've staggered drop and straight bars to aid the fit.
If you have an IKEA nearby these read-made brackets are cheap and cheerful, I keep several handy for jobs like this. I like some of the solutions above though, I can feel a small project coming on!
[url= https://s6.postimg.org/8nvbcesrl/IMG_20170118_095800.jp g" target="_blank">https://s6.postimg.org/8nvbcesrl/IMG_20170118_095800.jp g"/> [/img][/url][url= https://postimage.org/ ]image upload with preview[/url]
Bookmarking this for future, some great ideas here.
