Bicycle glasses for...
[Closed] Bicycle glasses for high long sighted prescription
[#7270166]
So my old spare specs aren't cutting it on the bike as I get a wee bit faster on the bike and I reckon I need to get some new more robust bicycle glasses.
Been looking online at some specs, like the Tifosi duro and after querying whether each of my selection can be re-glazed to my prescription, I've been told 'no, won't work well with your +5 prescription'.
So has anyone here had any experience with getting biking glasses with a high prescription ? As going through all the options could take bl**dy ages and I'd like to sort some out asap.
Can anyone help ?
Posted : 16/08/2015 9:52 pm
 aP
Rudy Project Maya will take that prescription - mine is -11.
I am told that Adidas frames should do.
Also Rupp+Hubrach.
When I was Italy recently I was told that Alpina shields will glaze with high prescriptions as well.
Posted : 16/08/2015 10:11 pm
Rudy Project Rydon with Rx insert takes my +5 prescription. Love mine and use them for road and off road. The photochromatic lenses always seems just right to me. I had mine glazed with very high refractive index glass. there is distortion, but the brain adapts pretty fast.
I've not looked at single glazing for the same reasons as you - too high prescription.
Posted : 16/08/2015 11:50 pm
Same as TiRed but with Rudy Project Noyz. Only problem is fogging when riding off road. I tend to use contacts for those days.
Posted : 17/08/2015 9:21 am
 nerd
I have some Adidas Evil Eye Pro glasses with a prescription insert to -6.5 in one eye and -7 in the other with astigmatism of 1.85 in each eye. I'm very short sighted.
They work very well with two caveats: my eyelashes sometimes brush the inside of the lens, leaving a greasy mark that I have to clean off. Also, they fog up when I stop, but are fine when moving. I think the first problem could be solved by glazing them with a high index lens, rather than a standard prescription.
I tried contact lenses but I have a very strong blink reaction that I could never get rid of. Putting in / taking out the lenses could take 1/2 an hour!
Posted : 17/08/2015 9:27 am
I've been meaning to get some prescription riding glasses for a long time now. Is this the sort of thing people tend to do online, do I need to find a specialist sports shop (my LBS doesn't do glasses at all), or can I buy some glasses from CRC and rock up to Specsavers to get the prescription bit?
Posted : 17/08/2015 5:43 pm
Unsure of how well online specification of my prescription would translate to some Adidas, Rudy Project or Oakley* stuff I had my most recent prescription in some Rx insert type i828s. Sure they're not 'the coolest' but they come with interchangeable lenses - clear, dark and amber.
Sweaty and foggy on hot and humid days. All good otherwise and when moving.
*If anyone has any positive feedback on these I'd be keen to know. I'm 6.5 & 7.0 if that helps.
Posted : 17/08/2015 6:45 pm
Thanks guys, some options to look at there, the Rudys and Adidas (which for some reason surprises me)
But am I right here in that RX inserts are the way to go ?
So for the larger (blinder) prescription getting the main lense glazed isn't really an option unless I fancy blurry distorted vision ?
Bit of a PITA but hey ho.
Posted : 19/08/2015 9:57 pm
High plus and minus prescriptions can be hard in 'wrap' frames leading to thick lenses and distortion. Inserts negate this issue as they're only a small lens but that goes with a limited field.
Best option would be contact lenses and plano [no power] riding spex, then you can pick whatever frame you want.
Posted : 19/08/2015 11:12 pm
ironnigel, What are the i828's ?
Posted : 03/09/2015 8:26 am
