Bib shorts- do you ...
[Closed] Bib shorts- do you get used to the straps? (I hate the feeling)
 hora
I've been using normally lycra shorts- everytime I try on (big enough) bib shorts I still feel constrained, very conscious of the feeling of being 'pressed down on' on the shoulders. Do you get used to this, does it feel reassuring for some? What are the benefits- apart from in winter?
I can't used to it. Really don't like it- does that go away?
Posted : 09/04/2015 10:38 am
Always feels odd the moment I put them on but after a few minutes I don't notice them until it's time to take them off.
Sound like the pair you have are too small in the body IMHO.
EDIT: Odd as you describe, causing me to hunch/feel constrained.
Posted : 09/04/2015 10:40 am
 aP
Err.... never been a problem to me. The benefit is that you don't have to have a tight waist band to stop your arse crack from showing.
You could always train for bib-shorts by wearing lederhosen during the week?
Posted : 09/04/2015 10:41 am
They are awesome, just about replaced my older normal shorts. When you are on a bike you are more in the position for it to be comfortable. Not going back.
Maybe you should try some the right size? 😆
The benefits for bib shorts/longs are that you don't have a tight band around your midriff and there's material covering your lower back when you are cycling along.
The disadvantage is that when you are desperate ...
Posted : 09/04/2015 10:44 am
How many different brands have you tried?
My first bib shorts were dhb ones and they fitted right everywhere, but were a bit short in the bib strap department, so it always felt like they were pulling on my shoulders.
My latest favourite bib shorts are Lusso ones and once you've got them on and on the bike, you cannot feel the bib part at all. You can feel them a little bit when off the bike, but that's presumably because you are stretched out a bit more.
I've also tried some more dhb ones and they are fine, so either my spine has got a bit shorter or the bibs on these ones are a bit longer than the original ones I had.
Posted : 09/04/2015 10:45 am
 hora
XXL Morvelo's. The legs/arse weren't that tight and the sizing says 6ft4 (I'm 6ft2 but with a longish trunk).
I've found this on quite a few bib shorts- I have to go crazy high when trying them on and I still feel 'constrained' by the straps so end up not buying any of them in the shop(s).
Posted : 09/04/2015 10:48 am
hora - Member
Constrained when stood up or when sat on a bike in the shop?
I imagine that most of them feel a bit tight when just stood up but when you are in a riding position the tension in the straps isn't so high and they don't feel so 'constrained'.
If they were comfortable loose when stood up straight, you'd probably find they wouldn't be very effective when sat on the bike.....
Posted : 09/04/2015 10:51 am
They can be a bit tight on the shoulders when new, but they do loosen up a bit. Love mine, hate catching a baggy crotch on the saddle nose on or off road.
Posted : 09/04/2015 10:53 am
i find they stretch a little with use, new bibs can be a bit 'keen'.
Posted : 09/04/2015 10:54 am
My dhb ones cut in on the shoulder a bit.
Howies 3/4 bibs are the most comfortable I've ever used.
Posted : 09/04/2015 10:56 am
The main advantage to me is no cold or wet/gritty lower back/butt crack. Also, like them never falling down!
Posted : 09/04/2015 10:57 am
I've not tried loads of different ones, but i know the feeling you're talking about. I have some madison 3/4 ones that are too long for me and the straps feel ok. some decathlon ones that feel constrained as you say. But the best I've got is some addidas ones that are super comfy and well sized for the less athletic cyclist shall we say!!
Posted : 09/04/2015 10:58 am
If it's any help i'm 6'2 with a longish trunk (32") leg and I find lusso bibs in large the best fitting out there.
Weird off the bike yes but when on the bike great. Helps keep the belly tucked in too... 😆
 hora
 core
I wear bib's on most rides, once they're on, after about 5 minutes I forget about them, just persevere, they're so much better than standard shorts.
Posted : 09/04/2015 11:03 am
I am similar - Scott seem to fit well.
Posted : 09/04/2015 11:04 am
most of the better quality ones are cut for "on the bike posture"
and will, therefore, be tight when stood. there's also the style of the
strap. Some have seems on the strap, some don't.
Posted : 09/04/2015 11:05 am
 hora
Ah but standard lycra shorts show my lovely [i][b]backwings[/b][/i]. The geometry of my new road bike is more 'racer' so I'm stretched out more thus showing the world the hardcore diet training regime of a mamil 8)
Posted : 09/04/2015 11:07 am
I know that feeling but find it disappears once I sit on my bike. The straps always feel too short when stood up but as soon as you get into a riding position all is sorted.
Posted : 09/04/2015 11:10 am
 kcal
The Morvelo ones - for me - feel like they are constantly pulling me into a clamshell posture.
They are also quite bracing across the front.. Sizing is key. Endure ones have a bit more give in the strap dept.
Posted : 09/04/2015 11:15 am
 hora
When you say bracing- holding you in?
Posted : 09/04/2015 11:16 am
you could get some of the new giro ones:
http://www.giro.com/eu_en/ride-halter-bib.html/
Posted : 09/04/2015 11:17 am
 hora
^That has Yardie weed-smoking gangsta allover it 😯
Posted : 09/04/2015 11:20 am
Our club bib shorts (can't remember the make) definitely feel too short when putting them on and stood up but are fine when actually riding.
Posted : 09/04/2015 11:22 am
I wear bibs under my MTB baggies and have found the same as you that they can pull down on my shoulders when stood up.
It's getting better though and after a couple of mins i barely notice them now. No worse than a pack with a full camelbak in
Nearly shat mesen on saturday morning trying to get out of them when the two strong coffees kicked in before my ride 😯
Posted : 09/04/2015 11:26 am
Horrible things.. Only any use imo for longer, harder rides where the lack of a waistband can help me avoid any stomach ill-feeling when eating junk or 'energy' foods, get similar issues when riding with a waist pack. Rode with bibs on a very long ride once where I knew stomach issues were likely and regretted it every time I needed to squat in the bushes in the cold.. : )
Posted : 09/04/2015 11:31 am
 hora
So apart from hiding/stopping your wings from getting cold and holding your tummy in- anything else?
Posted : 09/04/2015 11:33 am
Bibs are the most specialised of all cycling clothing in that they only work whilst sat riding a bike. Off the bike they look hideous, feel odd and are impractical. But sit on a bike and ride it and they work, they're more comfortable, look fine under a jersey and just plain work.
Posted : 09/04/2015 11:38 am
I have some Altura 3/4 bibs which give me the 'hunching' feeling, but my regular bib shorts (Gore/Mavic/Castelli) are all fine. I think the 3/4 ones I have are made of thicker Lycra generally which might be a factor?
RM.
Posted : 09/04/2015 11:40 am
I find that bibs that fit my arse, tum & thighs are too short in the straps, if the straps fit then the rest is baggy & looks 2 sizes too big.
Those lusso ones above- I'd need xl for height but L for fit 🙁
Posted : 09/04/2015 11:43 am
doesn't 'back wings' refer to well developed lats? not sure that shorts will change it one way or the other. More relevant is bibs providing a spanx-like effect on the midriff instead of creating a muffin top.
Once you're bent over the bars and not stood up getting your bollocks squashed bibs are *much* comfier.
Posted : 09/04/2015 11:45 am
Stay away from the teeny Italian stuff Hora. Get some proper man sized bibs a size up too. DHB are fine, or FLATB. And yes, they're all designed to be a bit more comfy ON the bike.
Posted : 09/04/2015 11:46 am
Hora, try some other bibs. I have morvelo ones and they feel tight and uncomfortable when stood up and just about ok when on the bike albeit still a fraction over snug. I think the Morvelo stuff comes up short in the body (or i'm long in the body) as I can't wear their cycle jerseys either. Apparently castelli is longer in the body although no personal experience.
Posted : 09/04/2015 11:50 am
DHB work for me and I'm not exactly the emaciated roadie stereotype. Also seem to be long enough in the straps despite having a long back (aka short legs) and not sizing up.
Do they make any where the strappy bits unclip?
Be handy not to have to get totally undressed when you need some relief while out on the trails/road.
Posted : 09/04/2015 11:57 am
@andytherocketeer
I've some full length bib trousers that have clips on the straps but TBH they are a bit of a pain as on me they are very close to being *on* the shoulder. I can't remember the make but they don't have a liner so you need to wear shorts or a liner insert with them anyway.
Also they are a right faff to get the straps connected back up if you do need to undo them as the back half invariably ends up stuck halfway down your back under your jacket/top.
Posted : 09/04/2015 12:00 pm
I love mine, the feel of the leather against my thighs is a sensation to experience, its that soft smooth leather that feels cool to the touch. The buckles don't chafe at all either and the soft padding on the shoulders is a delight. Having a button up front is great too, no more awkward fumbling if your caught short in the cubilcles. What sets it all off though are the lovely little details, the carved ivory chest piece and the leather lacey thigh expanding tie ups. Stains rub right off with a moist chammy or a wire brush if your so inclined. The most challenging thing is trying to cycle with the bit and bridle on, the reins catch on the bar ends and shifters.....
[url= https://farm8.staticflickr.com/7720/16899370908_990f094c3f_b.jp g" target="_blank">https://farm8.staticflickr.com/7720/16899370908_990f094c3f_b.jp g"/> [/img][/url]
[url= https://www.flickr.com/photos/musselburghbikers/16899370908/ ]IMG_0441[/url] by [url= https://www.flickr.com/people/musselburghbikers/ ]Andrea & Rick[/url], on Flickr
Posted : 09/04/2015 12:01 pm
I think you need to ask yourself "Is this bike riding malarky really for me?". You do seem to have an incredible amount of issues with it.
Posted : 09/04/2015 12:05 pm
 hora
Every man needs a folly for his spare cash.
Posted : 09/04/2015 12:10 pm
I'm the complete opposite to you Hora, anything other than bib shorts just feels wrong while cycling, I wear baggies with braces over the top when on my mountain bike as I hate the sinking shorts feeling.
I've been wearing them since 1979 for cycling so it just seems natural.
As others have said Lusso & DHB suit my long torso @ 6'3" Pearl Izumi also seem better sized at the XXL end anyway, though XXL chest size listed as 42"-44" is way off for someone with a 50" chest.
Posted : 09/04/2015 12:28 pm
I'm 6'3
I've got lidl/aldi bib longs, and some dhb longs, both fine
Wore Gore short bibs on the commute this morning, again fine.
Sometimes a bit strange when you first put them on, but fine when they've been on for a bit
Posted : 09/04/2015 1:50 pm
 D0NK
£26!
sold! Gonna order a pair of them.
Bibs are good [b]if[/b] you don't have any other sort of waist strap, 'bak waist straps or baggie/longs waist bands kinda defeat the object otherwise not much point to them as I don't really have a problem with cycling shorts falling down. Longs or baggies are a different matter, I always go for biblongs.
Just bibs and a jersey on when it's warm is pretty comfy and cool, if unsightly. I do notice the lack of waist band, but it's one of those minor things.
Posted : 09/04/2015 2:22 pm
those Lusso are a bargain, and you're supporting UK manufacturing as well (Radcliffe, near Bury)
Posted : 09/04/2015 3:33 pm
 Goz
always slightly tight when stood up, fine in the riding position!
Posted : 09/04/2015 4:52 pm
^^^ mostly this. Only exception is a pair of Santini bibs I have, still a bit tight on the bike and gives me a mild wedgie. If you are long of trunk I'd avoid Santini.
Posted : 09/04/2015 4:59 pm
Try loads, shorts are OK as well, I've no pairs that are uncomfy enough that I wouldn't wear them.
Posted : 09/04/2015 5:07 pm
Rickmeister, we see you wandering around at Eurobike every year don't we?
Posted : 09/04/2015 5:25 pm
Imagine it's all about the sizing and stretchiness.
Maybe I got lucky but bought a pair of Lusso that just felt like a glove and honestly the best bit of riding kit I ever had. worn in summer with nothing else but shoes is something else. Unfettered and free of sweaty nonsense. Like a slick vitamin-D harvesting flying über-being swimming through the air. Except on a bike. Sort of.
Posted : 09/04/2015 5:46 pm
I thought bibs felt strange when I first tried them.. The first proper hill puts all thoughts of what I'm wearing completely out of my mind.. I don't usually remember them til I get home to torment my gf with my fairground strongman routine..
I would suggest focussing harder on your riding
Posted : 09/04/2015 6:00 pm
Even after several years of wearing bibs the novelty of this this hasn't worn off. 🙂
Posted : 09/04/2015 6:39 pm
 hora
After this afts ride Im waiting for my balls to redescend.
Posted : 09/04/2015 6:55 pm
 D0NK
so probably less than 10miles from my LBS who can't currently get lusso stuff in 🙄 *
Don't suppose they have a factory shop do they?
*Yeah I know it doesn't work like that.
Posted : 10/04/2015 11:44 am
 hora
Radcliffe- that is local. I didn't know that- I'll buy some of their kit as I always try to buy UK manufactured where possible.
apart from splaying and crushing my nuts up- the loosening will relax round there right? I literally had to pull them out....yes TMI..
Posted : 10/04/2015 11:56 am
not while I'm eating my lunch! 😡
Posted : 10/04/2015 12:43 pm
Stop buying from the childrens section and get some that fit.
Bibs are comfy when they fit right..
Posted : 10/04/2015 12:57 pm
Morvelo shorts are tight, take a good while to 'loosen' but dont do so by much. If your getting issues in the crotchal region as well as height, id just move on to another brand now. Love mine, but if i put on any weight at all they would be a no go.
Posted : 10/04/2015 12:59 pm
you're doing it wrong
Posted : 10/04/2015 1:00 pm
 hora
Well Ive already worn em. I'll give em another couple of rides and also try Lusso. Im hardly hung like a powerful Shire horse. More a Pit Pony.
I wont be putting thrm up for sale though. Thats grim
Posted : 10/04/2015 1:01 pm
Never been impressed with Lusso myself. Sure they are cheap-ish and made in the UK. However, the cut on the jersey I have of theirs is weird and the 2 rear pockets are annoying to get balanced compared to the normal 3. The other stuff I had of theirs all unraveled after the first wash. I wouldn't totally rule them out, but it is cheap for a reason IMO.
As for bibs, they are fine just get a pair that fit and man up.
Posted : 10/04/2015 1:08 pm
Hora, I'm the same height as you and a similar 'solid' build. Not a chubber like you, obviously, but I used to be before I started riding loads of miles a month. I've only ever used these bibshorts and they're incredibly comfortable and fantastic value for money too. Especially as they're on offer from Ribble at the mo, with £20 off. You'll want the XL size.
[url= http://www.ribblecycles.co.uk/sp/road-track-bike/Lusso-Pro-Gel-10-Panel-Bib-Shorts-Black-XL/LUSSZBBS380? ]Lusso Pro Gel[/url]
Posted : 10/04/2015 3:47 pm
Give these a go - http://www.sigmasport.co.uk/item/Assos/T-rallyShorts-s7-MTB-Bib-Shorts/7J84?gclid=CO3y5O3N7cQCFUyWtAoduncApg
I use the Scott ones (start cycles) but buy a size up to reduce squashage.
Posted : 11/04/2015 7:26 am
 hora
Aye girls at work say Im sturdy/solid but not fat/overweight looking. If I was a female that'd be an insult. 😀
Posted : 11/04/2015 7:49 am
Posted : 11/04/2015 7:58 am
 OCB
Should go without saying, but (ime) wider straps are more comfortable too ...as is taking that extra second or so to make sure the straps aren't twisted (oh, and to make sure they are sitting properly over your nipple piercings of course).
Echoing comments above, but I find that anything other than bibs now feels weird on a bike. I find them great at this time of year when you just need that little extra layer at the bottom of your back, but don't need an extra layer anywhere else. (This might be an age thing).
Posted : 11/04/2015 11:36 am
I can now recommend Howies shorts, they are very good indeed. Probably better than my castelli and rapha ones.
Posted : 11/04/2015 11:41 am
I bought some of those Lusso pro-gel bibs from Merlin a few weeks ago. Most comfortable shorts I've ever worn, oh & only £44.95 too.
Posted : 11/04/2015 12:29 pm
