Bfe Gearing issues
[Closed] Bfe Gearing issues
3 Users
Hey.
Need a bit of help with shimano Xt gearing issue on my Bfe
So last week i snapped the Rear mech hanger off when a stick got caught in my my Derailleur.
Bought a replacement and refitted the derailleur and since then the gear haven't been able to get the gears set up right.
They do settle into the cassette but anytime I have to put my foot down they start to slip and jump.
So the questions is, is this a problem with the derailleur or the new mech hanger as its really getting on my tats.
Posted : 29/03/2016 2:24 pm
Is the derailleur bent?
Is the new hanger straight? (Not at all unusual for them to be bent once they are all fitted and clamped up with the rear wheel, get a jig on there)
Posted : 29/03/2016 2:41 pm
I think it must be the derailleur that's bent. Pretty sure the hanger is straight.
Posted : 29/03/2016 2:46 pm
OK.
Is your replacement mech definitely the same as the one you broke - i.e. is it 9/10/11? My mate had a problem and it turns our he'd fitted a 10 speed to a nine speed shifter and mech.
The mech hanger is most likely bent. How have you checked? Visually isn't a great check. You need a mech hanger alignment tool to judge this properly.
I used one a couple of times and was amazed at the difference it made to a 'visually straight' hanger.
Tried all of the above? Upper and lower stops set correctly? Cable grip done up tight? No crap inbetween the cables and outers?
Posted : 29/03/2016 3:29 pm
Maybe i have got the wrong are mech hanger. How would i know?
Posted : 29/03/2016 5:30 pm
