best way (on the ch...
[Closed] best way (on the cheap) to remove frame paint
Want a bear look to my frame, I was thinking wet and dry paper??
Posted : 03/05/2013 7:56 pm
Try taking it out into the wilds of Canada and tying sausages to it.
Posted : 03/05/2013 8:01 pm
Try a local chemical stripper. I only pay £10 for a frame. No way would I go back to sandin the paint off. Takes ages, is hard work and by the time you have bought a selection of sand papers probably not much cheaper.
Andy
Posted : 03/05/2013 8:03 pm
scaled - Member
Mouthful of beer over laptop after reading that.
Posted : 03/05/2013 10:07 pm
nitro mors does the job well, its nasty smelly stuff though.
Posted : 04/05/2013 12:09 am
Get it bead blasted.
Posted : 04/05/2013 12:13 am
F-kin brilliant "scaled"
Posted : 04/05/2013 7:11 am
Nitromors is shit...it has been since they took the chemicals out of it that were good at actually stripping paint.
there's a product called remove all ,its water based and doesn't try to melt paint but debonds it at a molecular level..
It will strip any paint up to 2k epoxy
find a place that's sells it its about 25 quid and you and your mates can share it
Posted : 04/05/2013 7:20 am
Paramose....e.g.
http://www.agwoodcare.co.uk/Item/paramose_ww_stripper
Posted : 04/05/2013 7:33 am
Sand blasting best method - but not always easiest.
Specialized frames are always hard work to do.
Chemical paint strippers easiest option. Can take a few applications and be messy though.
Posted : 04/05/2013 7:36 am
