Best method to fix ...
Best method to fix new pannier clips to old Karrimor bag
The original clips on my Karrimor bags won’t fit a 12mm rack
So I bought some other clips to see if they would work
The original clips (red coloured) have grooves in the plastic that kind of clip into the rail on the bag. Then you simply screw a small screw in
The replacement clips (blue) are a flat profile.
What do you think the most secure method of securing the new clips onto the rail might be.
There isn’t much space behind the rail btw. (I’m not sure a bolt would fit behind)
https://flic.kr/p/2oJ18rF
https://flic.kr/p/2oJ2hZH
https://flic.kr/p/2oHWi9H
https://flic.kr/p/2oHZomE
https://flic.kr/p/2oHWhMq
Posted : 18/06/2023 7:59 pm
I'd put a washer on it and a screw with a corse/self tapping thread.
or drill the rivets out and replace the whole rail assembly with a replacement full kit, you can buy Ortlieb ones.
Posted : 18/06/2023 8:55 pm
Did the same swap and I think I used the self tapping screws in the above link.
Posted : 18/06/2023 10:50 pm
 csb
I ended up doing this to refurb an old pannier. Worked perfectly.
Posted : 18/06/2023 11:10 pm
Would a self tapping screw be strong enough. I know that’s how the original clips are fastened on but they have a ridge in the plastic that also kind of clips into the rail.
Posted : 19/06/2023 10:35 pm
